14b oil lines and size
can someone help me with what size oil feed line i should get for a 14b turbo. i need to know the size of the line and the thread size to screw the line into the turbo. i also need to know what size oil return line to get and the size threads to screw in return side of the turbo
thanks
I can't remember which one it is, but it's either an 12mm or 10mm banjo bolt and banjo. I think it's 10mm ID.
I use the plated steel ones from Goodridge.
Part numbers:
776-03 = -3AN flare with 3/8", 10mm ID - use with 10mm banjo bolt and aluminum crush washers
776-04-M12 = -4AN flare with 12mm ID - use with 12mm banjo bolt and aluminum crush washers
The banjo bolt, crush washers and etc. are probably available from the dealership or from RRE.
If you want, I can get the stuff from my former roommate off of his 3G Eclipse since he's returning it to stock.
Part numbers:
RC000E
May 4, 2007 08:47 PM
TheIntegraGuy
Aug 21, 2005 11:01 AM
