Swapped 91 Civic fuel question
Old Jun 23, 2005 | 06:18 PM
Savarese's Avatar
Default Swapped 91 Civic fuel question
Hey I'm peicing together a turbo kit for my b16a swapped 91 civic. Do I buy a fuel pump for a 91 civic or a 2000 civic si? Also how can I get some ob1 injectors to work in a ob0 car?
Old Jun 23, 2005 | 06:28 PM
BlueShadow's Avatar
Default Re: Swapped 91 Civic fuel question (Savarese)
If you are buying something like a Walbro fuel pumjp you wanna worry about what kind of adapter/connector kit they send you. The type of motor you have doesn't make a difference, just tell them what kind of car you have.
Check out http://www.lightningmotorsports.com and you'll see that all the pumps are pretty much the same, but the adapter kits are different for each car.
EDIT check out the install kits and you'll se each car has a different part number:
http://www.lightningmotorsport...s.htm
Old Jun 23, 2005 | 06:41 PM
Savarese's Avatar
Thanks a lot! and if anyone can help me with the injectors I would greatly appreciate it.
Old Jun 23, 2005 | 07:20 PM
BlueShadow's Avatar
Default Re: (Savarese)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Savarese &raquo;</TD></TR><TR><TD CLASS="quote">Thanks a lot! and if anyone can help me with the injectors I would greatly appreciate it.</TD></TR></TABLE>
What kind of injectors are you using now? And what size injectors are you wanting to upgrade to? I'm assuming you have a first gen B16 with the stock peak and hold injectors and a resistor box?
If you are currently using peak and hold, you can buy a bigger set of injectors that are also peak and hold. I'm not sure if you can plug them right into your injector clips though. When you buy injectors you can request injector clips that plug into the new injectors and then you just wire it in to your. Hopefully somebody can help you out more with that. If you are going to order bigger injectors check out wiredspeedlab.com. Ricky at wiredspeed might even be able to help you out with your question.
Old Jun 23, 2005 | 08:41 PM
ProjectDarkBlack's Avatar
Default Re: (BlueShadow)
89 shipped for my 255 with the install kit, took 1 week
bamfasm
Jan 26, 2006 04:12 PM
racingant
Jul 24, 2005 12:04 PM
