'94 Accord DX doesn't want to start all the time. Hesitates for a few seconds and smooths out... bu
Old Jun 23, 2005 | 06:16 PM
wijiwang's Avatar
Default '94 Accord DX doesn't want to start all the time. Hesitates for a few seconds and smooths out... bu
'94 Accord DX 2.4 doesn't want to start all the time. Hesitates for a few seconds and smooths out... I can't figure out what is wrong. I have to make sure I'm giving it gas when I turn the key because if it does act up on me and I let it die, it is hard to start back up. The engine just keeps turning over.
My battery is not draining so I do not think it is the starter. I have recenty had the head gasket removed, but it was acting up once or twice before that. I regularly change my oil/filter and air filter.. but, I'm not so sure the last time I changed my fuel filter.
The thing is, it doesn't act up any other time. Only when I first start it, and only for a few seconds before it smooths out. It's weird, usually it starts ok. It usually gives me problems if it has warmed up and turned off earlier. Like when I go in a store. It doesn't hesitate when I give it gas going down the road, or when I decelerate.
That's what is throwing me off. I live in florida so it doesn't get cold.
Also, it is not my.. um.. forgot the name for it.. fuel pump relay? I hear it click every time I turn the ignition switch. I'm afraid it could be a few hundred dollar fix. I hope it isn't because I'd rather spend that money on a new suspension and tires. Have you ever had a similar problem?
P.S. 190,000 miles and going strong. Any ideas? Thanks
Old Jun 24, 2005 | 07:27 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: '94 Accord DX doesn't want to start all the time. Hesitates for a few seconds and smooths out..
Tune up?
Old Jun 26, 2005 | 02:48 PM
BLKFLSH's Avatar
sounds like fuel pump or pressure regulator. My 92 was doing that, turned out to be the fuel pump. (inside gas tank)
sas6709
Apr 12, 2012 04:34 PM
gruegrimman
Oct 5, 2007 03:04 AM
ScentlessCheese
Jul 21, 2005 07:24 AM
fcuk_it
Oct 18, 2004 11:38 PM
