Is this what I need for a swap?
Old Jun 23, 2005 | 06:09 PM
jdmrider's Avatar
Default Is this what I need for a swap?
I should have pretty much all I need but I have a question about the wiring on an EF/B16 swap I'll just list all I have and you guys tell me what else I need or what? The car now has a good ole 4 on the floor. 4spd
1. b16 eng,ecu,tranny,
2. 90-93 integra hubs
3. Integra axles
4. engine mounts
5. delsol shift linkage?? I have it but I'm not sure if it will work
I need the car converted to MPFI but I'm not sure what exactly has to be changed.
Any help would greatly be appreciated.
Old Jun 23, 2005 | 07:09 PM
Crx Jimmy's Avatar
Default Re: Is this what I need for a swap? (jdmrider)
just buy the custom linkage- its under $100, get all the harness you need from rywire or similar if you are not that confident with your wiring skills, it should almost be a plug and play then
Old Jun 23, 2005 | 08:18 PM
leono's Avatar
you got just about everything you would need.
Old Jun 23, 2005 | 08:22 PM
crxnj's Avatar
Default Re: (leono)
Remember to dent the inner fender for alternator clearance..
Old Jun 23, 2005 | 09:07 PM
NikoZai's Avatar
Default Re: (Mr.speaker)
checkout http://www.rywire.com for the wiring. You can call the phone # and ask a ton of questions as long as you buy something LOL j/k.
jons91ef
Jun 6, 2008 10:48 AM
crxpwr1
Jun 5, 2006 02:51 PM
Wasabithegosu
Jun 10, 2005 08:04 AM
MysteryWagon
Aug 29, 2001 10:36 PM
MysteryWagon
Jul 5, 2001 05:54 AM
