grindding 1-2 question
From: Boswanna,street radio,riddin in da regal. PA.LLday
hhey guys im new to the s2k but i have a 2000s n im wondering if there is any way to get rid of the 1-2 grind...cheapest like i hope a newer tranny is the route i would have to take... any way im preparing to put in some gm messh in a few days to help it a bit but i know it would solve problem ...it just frustrates me when it happens i know u guys understand...so help me out on this thanks
what do u think about a new clutch? i mean if i drive normal it never happens...but if im messin around every now n then it will happen when i hit vtec n ride out first but doesnt do it all the time...i know its not major n it just a honda thing for the s2000 but i was just wondering if there was anyway to solve
the grinding is caused by the honda synchoniser and the selector collar not by the gears per se.
It often happen at high rpm. It's the inherent problem in our gearbox/synchoniser design. It helps with gm or redline fluid but if it gets very bad you will need to order new synchro.
Alternatively you can get a dogbox and you will not have to face this problem or gear failure. This is not cheap or readily available solution though.
yea im gonna put some gm mesh in n deal with it i think but if u take it to the dealer let me knoww what they say
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeGmAn18 »</TD></TR><TR><TD CLASS="quote">any thoughts on how much the synchro would be?</TD></TR></TABLE>
Have you tried calling a local transmission shop for the synchro??? If they have it, most likely it would be cheaper than OEM.
