ctr rear lips on eks...what are you using to hold the center up?
Old Jun 23, 2005 | 02:07 PM
Nothing.Special's Avatar
Default ctr rear lips on eks...what are you using to hold the center up?
justl ike the topic says, i have a ctr rear lip on my ek and what should i use to hold it up on the center, its hanging a little and melting on my exhaust
Old Jun 23, 2005 | 02:30 PM
opiumdaze's Avatar
Default Re: ctr rear lips on eks...what are you using to hold the center up? (Nothing.Special)
i just used double sided tape and put it how i like.. it seems to hold up pretty good
Old Jun 23, 2005 | 02:33 PM
undertheradar's Avatar
Default Re: ctr rear lips on eks...what are you using to hold the center up? (opiumdaze)
When I had mine on my coupe I used a long bolt under the two sections where they curve in towards the middle. Did a good job of keeping it nice tight.
Old Jun 23, 2005 | 02:34 PM
AGS's Avatar
AGS
the JDM **** one that I had fit real tight and was able to stay up, however i also put double sided tape on the back to help it out.
As for the melting...i let it melt! Made the exhaust fit in there real nice.
Old Jul 15, 2005 | 01:26 PM
SiR EJ8's Avatar
Default Re: ctr rear lips on eks...what are you using to hold the center up? (AGS)
zip ties own you.
Old Jul 15, 2005 | 01:29 PM
Airbag Club's Avatar
Default Re: ctr rear lips on eks...what are you using to hold the center up? (SoLo Accord)
are you referring to real or fake ctr lips? the real ctr lips have brackets molded onto the inside. when you take off your bumper, you'll notice small circles with a X through it. you drill out those holes and put a 10mm bolt through it...
Old Jul 15, 2005 | 01:31 PM
777sC's Avatar
i put screws into my fake one when i had my old EK ... held up fine and you couldnt see the screws either
Old Jul 15, 2005 | 01:35 PM
BS 22's Avatar
Default Re: ctr rear lips on eks...what are you using to hold the center up? (Airbag Club)
3M double sided tape.
Old Jul 15, 2005 | 01:37 PM
K.F14's Avatar
doubt sided tape
Old Jul 15, 2005 | 02:08 PM
JforJonathan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AGS &raquo;</TD></TR><TR><TD CLASS="quote">the JDM **** one that I had fit real tight and was able to stay up, however i also put double sided tape on the back to help it out.
As for the melting...i let it melt! Made the exhaust fit in there real nice.</TD></TR></TABLE>
i got the jdmshit lip too. it fit perfect. i just added the tape for added support also i had to dremel out an opening for my exhaust though
Old Jul 15, 2005 | 02:40 PM
distortedfuture's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoLo Accord &raquo;</TD></TR><TR><TD CLASS="quote">zip ties own you. </TD></TR></TABLE>
Old Jul 15, 2005 | 03:07 PM
-Todd-'s Avatar
Default Re: ctr rear lips on eks...what are you using to hold the center up? (777sC)
I used bolts and nuts.
Old Jul 15, 2005 | 03:34 PM
CgiRLGO's Avatar
Default Re: ctr rear lips on eks...what are you using to hold the center up? (BS 22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BS 22 &raquo;</TD></TR><TR><TD CLASS="quote">3M double sided tape.</TD></TR></TABLE>
Old Jul 15, 2005 | 05:08 PM
dh's Avatar
dh
Default Re: ctr rear lips on eks...what are you using to hold the center up? (CgiRLGO)
Weedydgaf
Aug 25, 2015 02:01 PM
VTECROAR96typeR
Feb 26, 2009 04:43 AM
Cashieboi
May 16, 2007 06:53 PM
GEO276
Feb 26, 2006 11:45 AM
DSC
Oct 17, 2002 02:45 AM
