Car will not go into gear
Old Jun 23, 2005 | 01:52 PM
LSVtechnologytur...'s Avatar
Default Car will not go into gear
Hey guys, i have a problem.. I just installed a new clutch(throw out bearing & Pilot bearing) and I am unable to put the car in gear when it's running. Also, there is a random knocking sound coming from the tranny.
any idea whats wrong?
-btw.. ls transmission, action clutch, cable trans.
Old Jun 23, 2005 | 02:13 PM
thelate1's Avatar
Default Re: Car will not go into gear (vtec'n)
one of the bearings in backwards? do you have pedal pressure? if not then i'd say it's a bearing issue.
this is the first thing that came to my head.....hth..............
Old Jun 23, 2005 | 04:14 PM
Default Re: Car will not go into gear (thelate1)
The bearings aren't in backwards, I have peddle pressure but it does seem wierd ( probably because its aftermarket) ... i guess i'll have to drop the trans and check it out
Old Jun 24, 2005 | 09:52 AM
bump... before i drop the trans.
Old Jun 24, 2005 | 10:02 AM
Joebroni's Avatar
You got the cable adjusted right? Have someone push the clutch in and see if the clutch arm will move up even more when the pedal is depressed.
Old Jun 24, 2005 | 01:24 PM
thelate1's Avatar
Default Re: (Joebroni)
yeah, what he said, check the cable....
also what clutch is it?
what do mean by it feels weird? hard to push or what?
Old Jun 25, 2005 | 08:54 AM
Default Re: (thelate1)
well i re-re-adjusted the clutch and i think it might have fixed it... except now my car cranks slower, floods, and barely starts..then dies in a few seconds. Is this because the clutch was so far off that it wasnt spining all that extra weight?
`btw i DO feel stupid for missing such a small problem
Themadone
Nov 19, 2006 06:56 PM
The Destroyer
18
Feb 24, 2006 06:26 PM
R_type
May 31, 2005 05:40 AM
TRE_
Jan 7, 2003 05:35 PM
