Accord dies during deleration? Help big time
Old Jun 23, 2005 | 01:16 PM
smkngsr's Avatar
Default Accord dies during deleration? Help big time
This is 91 honda accord LX Automatic and bone stock...nothing done to it at all...and for some reason the car will die during deceleration and when u start them, it will fire right up...what might be the problem...and also the battery does not reset because the clock still stay the same time when i turned the car on again...what might be the problem...thanks much
Old Jun 25, 2005 | 06:43 AM
smkngsr's Avatar
Default Re: Accord dies during deleration? Help big time (smkngsr)
suprising that no one knows this issue...somebody got to have an answer to this one...any feedback is appreciated
Old Jun 25, 2005 | 02:41 PM
Two4trippn's Avatar
Miine did something similiar and it was a bad battery cable connection and old battery. Once replaced, I had no problems.
Old Jun 25, 2005 | 05:03 PM
P_Adams's Avatar
Look for a component in the throttle boby called an Idle control motor. There comes a time where it and the throttle body need to be cleaned of pcv system residue and dust. What can sometimes happen is dirt builds up (it doesn't take much) interfering with the IACM's function, much like having dirt getting into the idle fuel port of a carburetor.
As to your batt / clock condition; let me think on that one
P
Old Jun 25, 2005 | 09:24 PM
skiier's Avatar
sometimes the mounting screws holding the Intake Air Control valve (IAC) vibrate loose and the coil doesn't work the valve properly and your engine "chokes" for air and stalls.
Look on the backside of the intake manifold behind the throttle body for a connector. Feel if it is loose, if so plug it back in. Jiggle the connector with the engine idling. If the engine stalls something is loose or broken.
This valve controls the air to the engine when u take ur foot off the gas.
Old Jun 26, 2005 | 12:38 PM
smkngsr's Avatar
Default Re: Accord dies during deleration? Help big time (skiier)
i will definitely take a look at that...what really suprise me the most is when the car dies, then i parked them, and crank it back again,,,the car runs perfectly like nothing happens to it...ive got a feeling that u guys are right...il let u know but if theres anythings else possible that i can check, pls feel free to add more comments or ask questions...thanks again
jimmy pockets
Jun 8, 2014 07:22 PM
Gix0r
Jan 16, 2012 04:31 PM
speed_n_blood
Feb 18, 2010 09:18 PM
blackrsx
May 3, 2005 10:00 PM
