cams in my jdm B18C
I have Crower 403 cams, springs and retainers from my 2001 gsr. My question is, are these useable on the type r motor. Is it worth it, or should I just leave it alone. Reason I ask is they are practically brand new, havent been able to sell, Also, got Kenji ecu and harness for car. That will give 9100 redline on my stock valvetrain. I already didnt have luck with gsr motor, dropped valve within 2 weeks. I think performance shop did faulty install. What would all of you do.
yeah you could definitely transfer them over to a type R motor. I believe all DOHC Vtec cams are interchangeable on any b-series vtec head.
how was the p28 ecu with your gsr? Any problems with the intake manifold not switching on the secondaries?
I used stock ecu when these were installed on my gsr. Did not get a chance to get new one for set up because motor went bye-bye. I just read an awsome thread in regards to valvetrains and cams, it seems that my stock valvetrain on type r can handle 9100 redline. Can someone clarify this whos actually done it. I cant afford to blow this motor and want to set it up so I can autox and drive the **** out of it. Autox I get stuck in 2nd gear and rev the **** out of the motor on those tight courses.
thehatchninja
Jun 10, 2005 11:37 AM
BoostedVtecGsr
Nov 3, 2004 08:10 AM
