no pull
My rsx-s (04) isn't pulling at all any more. I floor the gas and revs go up but i go no where. It still goes but it feels crazy slow.
Could this mean I need a new clutch? I have 25 k on it and learned on it too (beginner=burn clutch constantly). Someone else said my belt could be slipping from the underdrive pulleys i installed. any held would be good.
Definate clutch......if your belts etc were messed up you'd be getting all sorts of messed up performance... a burnt clutch will just rev without moving the car anywhere.
Totest clutch, get going about 20 mph. Put your clutch in, put it in 6th gear, keep clutch in, rev to like 6k or so, dump the clutch. Your rpm should pretty much immediately drop. If the rpm hovers at 6k (or anywhere it shouldn't be) then the clutch is bad.
jdmstyleEJ6
12
May 9, 2010 04:13 PM
