Checked fuses, and check engine came on?
Old Jun 23, 2005 | 12:07 PM
liquidscor00's Avatar
Default Checked fuses, and check engine came on?
I ws trying to replace my girlfriends brake lights. When I went to go install the new lights it didn't work. So I figure it could be a bad fuse. The car was on when i was checking the fuse and I went ahead and pull out the back up and instrument panel fuse and pluged it back in. after that the check engine came on.
How can I make it go away?
Its a 2000 Accord LX 4-door
Thank you in advance for your help guys.
Modified by liquidscor00 at 9:44 PM 6/23/2005
Old Jun 23, 2005 | 12:14 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Checked fuses, and check engine came on? (liquidscor00)
Check a manual or maybe someone here can help me out. Not sure which fuse it is, but there is one you can pull to reset the ecu. After doing that, plug it back in and turn it on, see if it's still lit up and let us know.
Old Jun 23, 2005 | 01:20 PM
will this reset the SRS light as well?
Old Jun 23, 2005 | 01:53 PM
NAiL05's Avatar
when u reinstalled it was the car still on?
Old Jun 23, 2005 | 01:56 PM
xbn83's Avatar
Try to pull out the back up fuse and put it back after 5 or 10s. The car has to be off. Hope the check engine light will be gone.
Old Jun 23, 2005 | 02:39 PM
Default Re: Checked fuses, and check engine came on? (NAiL05)
Yes when i reinstalled it, the car was on.
Old Jun 23, 2005 | 06:50 PM
theraab40's Avatar
why don't you just disconnect the battery for 5 mins
Old Jun 24, 2005 | 11:56 AM
NAiL05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liquidscor00 &raquo;</TD></TR><TR><TD CLASS="quote">Yes when i reinstalled it, the car was on. </TD></TR></TABLE>
Replace Fuses and take them out with the car off.
Cdeese910
Oct 25, 2012 07:56 AM
62maxx
Oct 25, 2006 03:45 PM
dizzyroc88
Jan 22, 2004 07:29 AM
Ludeboi
Apr 12, 2003 12:00 AM
