B16 gearing question?
Old Jun 23, 2005 | 10:17 AM
ASR_RAMBO's Avatar
Default B16 gearing question?
can i use s4c (B16) gearing into my ls cable tranny? and what kind os LSD im suposse to use? Need some info pls......
Old Jun 23, 2005 | 06:44 PM
annin's Avatar
Default Re: B16 gearing question? (ASR_RAMBO)
You can use the gears, including the final drive as it should bolt right onto your stock diff. Or you can just use the B16 differential w/o taking it apart. As far as LSD, you can use an ITR/CTR but you have to modify the clutch case slightly and use ITR ball bearings.
jdm_eddie
Transmission & Drivetrain
Nov 7, 2010 10:15 PM
str8JDMteggy
22
Nov 5, 2009 07:21 PM
1992db2
Jul 22, 2009 08:24 AM
hondaboyB18C1
Oct 22, 2007 03:12 PM
honda93
Aug 19, 2004 05:31 PM
