B16 swap injector wiring ?
Old Jun 23, 2005 | 09:58 AM
jamclaur's Avatar
Default B16 swap injector wiring ?
OK i just bought a crx with a jdm b16a swap that doesn't run. ( got a real good deal on it) and after awhile of looking and poking around i found that the reason it wont crank is that the # 3 injector is running a steady stream.like straight up pissing. i could aim with it. i changed out injectors and i that didn't help. so im guessing some wires are crossed somewhere. i was just hoping you guys might have some suggestions or at least give me an idea of where to start. thanks
Old Jun 23, 2005 | 10:46 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: B16 swap injector wiring ? (jamclaur)
i would try a known good ecu to start
Old Jun 23, 2005 | 11:03 AM
jamclaur's Avatar
I put in a good ECU when I first got the car to see if that helped, but no luck.
Old Jun 23, 2005 | 11:39 AM
NikoZai's Avatar
Default Re: (jamclaur)
Willing to bet, at the ECU, there is a wire from the old #3 injector touching ground. Pull back the carpet, check for loose wiring. If it's a DX and someone did a MPFI swap and did not tape off the 2 removed injector pins, it will cause the injector to open whenever the key is in the on position. Find that loose wire.
Old Jun 23, 2005 | 11:42 AM
was this car converted to multiport?
Old Jun 23, 2005 | 12:11 PM
jamclaur's Avatar
Default Re: B16 swap injector wiring ? (PURPLETERROR)
its an si.
Old Jun 23, 2005 | 04:55 PM
ant$missShift's Avatar
TTT
Old Jun 23, 2005 | 05:42 PM
Jdm90crxdxb16's Avatar
Default Re: (sxeonerX)
is it obd0 or obd1?
Old Jun 24, 2005 | 12:29 PM
Default Re: (Jdm90crxdxb16)
i assume obd0 ?
Old Jun 24, 2005 | 01:49 PM
jamclaur's Avatar
Pretty sure it's obd0...
Old Jun 24, 2005 | 01:50 PM
jamclaur's Avatar
Any other thoughts?
Old Jun 24, 2005 | 03:00 PM
jamclaur's Avatar
Bump
Old Jun 24, 2005 | 03:10 PM
NikoZai's Avatar
Use a volt meter and see if the ECU side of the 2 pin injector plug is constantly grounded.
If you don't know how to do this, read up on electrical on http://www.the12volt.com
If it isn't grounded all the time, the injector is stuck open.
I recommend http://www.witchhunter.com/ to have your injectors cleaned.
Old Jun 25, 2005 | 08:30 AM
jamclaur's Avatar
OK. Will do, if anyone has any other thoughts please post. I will post the results of what you guys said soon. Thanks a lot in advance...
Old Jun 25, 2005 | 02:36 PM
jamclaur's Avatar
lsvtek
15
Jul 10, 2012 02:28 PM
chrysanderson
14
Nov 7, 2010 09:08 PM
SweetDA9_TR
May 1, 2009 09:42 PM
SweetDA9_TR
19
Mar 18, 2009 08:10 AM
