Valve lash
Old Jun 23, 2005 | 08:59 AM
hAILO's Avatar
Default Valve lash
For a b series vtec it calls for 7 on intake 8 on exhaust. Would there be a benifit of running a tighter clearence i.e. 6 on in 7 on ex?
Old Jun 23, 2005 | 09:48 AM
mmuller's Avatar
Mad Scientist
Default Re: Valve lash (hAILO)
i would not run any tighter than what specs call for.
Old Jun 23, 2005 | 10:00 AM
hAILO's Avatar
Default Re: Valve lash (mmuller)
but in theory wouldnt that increase lift and advance timing which would transalte to HP? why would honda spec make int side tighter then ex? becasue it advances and adds lift to the intake cam?
Thses adjustments might be too minute to even make a difference, but hey thats what this place is here for right?
Old Jun 23, 2005 | 10:15 AM
mmuller's Avatar
Mad Scientist
the exhaust gets hotter than the intake..hence looser on the ex.
dont mess with that..specs are for a reason..look for power elsewhere.
Old Jun 23, 2005 | 03:37 PM
turbo_b16_ex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
dont mess with that..specs are for a reason..look for power elsewhere. </TD></TR></TABLE>
Old Jun 23, 2005 | 04:08 PM
allmotorSOHC16's Avatar
Default Re: Valve lash (turbo_b16_ex)
theoretically there is power there, but the question is it worth it, valve train damge can be fatal. keep it in spec.
Old Jun 23, 2005 | 05:08 PM
hAILO's Avatar
Default Re: Valve lash (allmotorSOHC16)
i dont see a problem if you motor is clayed...but i thought about this some more,and i guess it would be the same thing as just using your cam gears....
Old Jun 23, 2005 | 05:23 PM
Lord Helmet's Avatar
premature valvetrain wear= not worth it IMO.
Old Jun 23, 2005 | 06:10 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hAILO &raquo;</TD></TR><TR><TD CLASS="quote">i dont see a problem if you motor is clayed...but i thought about this some more,and i guess it would be the same thing as just using your cam gears.... </TD></TR></TABLE>
clayed?mmm. that would not really be the problem.by you tightening the clearance your really not adding that much lift at all...think about it..
without getting into it, what the guy above said is the reason.
jdmlude5
18
Mar 9, 2021 01:02 PM
BryanPendleton
17
Feb 24, 2005 08:51 AM
ghosts
Jan 5, 2004 03:39 PM
Behan
11
Jul 16, 2003 01:53 PM
Behan
Jul 15, 2003 08:30 PM
