Python 900 Alarm (Power Door Locks)
Alright, I have a python 900 alarm and i bought some after market actuators but i can't figure out how to set them up.. I have the installation manual and it does no good at all... The alarm says it comes with a built in relay for the keyless entry and it says that after market actuators can directly connect.. But i have no idea where...
Any help with this at all would be great..
- Dave
Modified by tweak at 3:59 PM 6/23/2005
- Dave
If the relays are built in then there should be a 5 or 6 wire harness, [2 wires may be connected together with a fuse] if so, the fused wire goes to a 12V+ constant power source, [12V+ constant freepin on fuse box if it's a Honda/Acura works good] the 2 wires marked (87a) or N/C, [normaly closed] both go to ground, [the dash grounds around the "A" piller (10mm bolts) work good if it's a H/A] that will leave you with 2 wires marked (30) or common, they go to the actuator wires, [connect the same color wires off the actuators together, then connect one of the wire left over from the alarm to one color set and the other one to the other color set. You may have to rev. the wires if the locks work the wrong way, so test it, before you make a permanent connection.
If you can show me the wire diagram, I can explain it better.
94
94
Hey, thanks for the info...
It turns out the 2 wire that meets with a fuse goes to the 12v power (like you said) then that left me with 5 extra wires, two were grounds 1 did nothing and the last two go to the actuator... so now my ghetto RS has keyless entry
Thanks for the help
- Dave
Thanks for the help
- Dave
B-Rabbit20
Aug 18, 2015 01:08 PM
Boosted_90Teg
Audio / Security / Video
Sep 14, 2010 07:41 PM
