FS: B18B/GSR Head
Old Jun 23, 2005 | 04:24 AM
unix4linux's Avatar
Default FS: B18B/GSR Head
Hello All,
I am selling a B18B1 Block with a GSR Head. Both have been worked on and have not been used/installed on anything yet. I don't want it anymore cause I am moving and could use some money for my new place. Everything is in perfect condition. I am asking $1000 for the head and I spent $1200...for the block I am asking $700...here are the details and the links below are the pics:
B18B1 Block:
Hot Tanked
Decked 5/10000ths
LS Crankshaft
Main Caps
Every Single Bolt and sensor for the block is included
Missing crankshaft pulley
LS Rods
.50 overbore
Integra Type R Pistons w/rings
Rods need to be machined to fit pistons
Alternator and bracket
All Gears for Timing belt including tension gear
Oil and Water Pump also included
A/C Bracket and Compressor
Power Steering Bracket and Pump
Oil Pan
Oil Pickup
GSR HEAD:
Skunk2 Valves
2 Ferrea Valves because its just the way I got the head but it will not affect performance at all.
Skunk2 Retainers
Bronnze lower and upper keepers
New Honda Seals
Skunk2 Springs
3 Angle valve job
Milled head
All Bolts except for head studs are included and valve cover
GSR cams
Stock CamGears
Vtec Solenoid
Sandblasted
I am willing to sell one item or both together but will not Part Out!!!
If you have any questions email me at unix4linux@tampabay.rr.com
Modified by unix4linux at 7:03 PM 6/23/2005
Old Jun 23, 2005 | 06:03 PM
unix4linux's Avatar
bump for the night
Old Jun 24, 2005 | 01:36 PM
unix4linux's Avatar
friday bump
stinner.5
Sep 26, 2012 08:22 AM
PLAN:B
Nov 18, 2005 09:17 AM
unix4linux
Aug 3, 2005 05:36 AM
unix4linux
Jun 3, 2005 07:17 AM
