90 EX Thermostat location.
Old Jun 22, 2005 | 08:44 PM
ptran's Avatar
Default 90 EX Thermostat location.
Looking to replace the upper and lower radiator hoses along with the thermostat. Where is the thermostat located? Any tips on replacing these items?
Old Jun 22, 2005 | 09:32 PM
NAiL05's Avatar
Default Re: 90 EX Thermostat location. (ptran)
Follow your lower radiator hose. It will lead to your thermostat. Location should be below the Intake Manifold or around that area. You should also see the coolant temp sensor deal.
Old Jun 22, 2005 | 10:45 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ptran &raquo;</TD></TR><TR><TD CLASS="quote">Looking to replace the upper and lower radiator hoses along with the thermostat. Where is the thermostat located? Any tips on replacing these items?</TD></TR></TABLE>
Yea, getting to the lower radiator hose is a PITA. My suggestion is to get under the car and look for the clamps, you might have to take off the fan on the passenger side to get at it. The upper is easy as pie. For this you might as well do a radiator flush since majority of your fluid will be coming out anyway .
Just when you're done bleed the cooling system (bleeder valve right by the t-stat) and make sure all your clamps are positioned to where you don't have to take the fan off to get to (lower hose) and that they are tight!
Old Jun 23, 2005 | 08:22 AM
NAiL05's Avatar
Default Re: 90 EX Thermostat location. (.ken)
Removing your intake will give you a lot more room to work with also.
Old Jun 23, 2005 | 08:16 PM
ptran's Avatar
Default Re: 90 EX Thermostat location. (NAiL05)
Which end of the lower radiator hose is the thermostat located at?
Old Jun 23, 2005 | 08:30 PM
NAiL05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ptran &raquo;</TD></TR><TR><TD CLASS="quote">Which end of the lower radiator hose is the thermostat located at?</TD></TR></TABLE>
On the block.
Old Jun 23, 2005 | 08:36 PM
The_Todd's Avatar
Farts in the shower
On the block where the lower radiator hose connects to the block. Actually the lower radiator hose connects to the t-stat then the t-stat connects to the block .
Old Jun 23, 2005 | 08:57 PM
NAiL05's Avatar
What .ken said. His explanation is more exact than mine. lol
Old Jun 24, 2005 | 09:30 PM
ptran's Avatar
ONE MORE QUESTION FOLKS:
Cant seem to find the bleeder valve. Is it simlar to the brake bleeder valve on the calipers? I see something similar to this by the lower hose on the block. If this is it, i would need to bleed it with a wrench, just like the brakes right?
Old Jun 24, 2005 | 09:40 PM
The_Todd's Avatar
Farts in the shower
It will look like the same thing...it has that same nipple on there and it is just past the lower radiator hose and right by the t-stat. And it should be exactly like the brakes except you run the car while the bleeding apparatus is hooked up and it bleeds out the air and when you get coolant wrench down the bleeder valve.
Old Jun 25, 2005 | 04:12 PM
ptran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken &raquo;</TD></TR><TR><TD CLASS="quote">It will look like the same thing...it has that same nipple on there and it is just past the lower radiator hose and right by the t-stat. And it should be exactly like the brakes except you run the car while the bleeding apparatus is hooked up and it bleeds out the air and when you get coolant wrench down the bleeder valve.</TD></TR></TABLE>
thunderfck
Mar 9, 2013 09:48 AM
soon2bdropped
Aug 15, 2010 06:18 PM
IntegraR0064
Jan 27, 2009 10:41 AM
fanta!
Aug 14, 2005 02:14 PM
e jay one
20
May 19, 2005 08:37 PM
