stupid question but instructions on lowering springs
i am planing to put in the pro kit lowering springs into my ek
please post a link or instructions i need step by step info
pic are also very helpfull and also supplies are key
have you looked at you suspension? its a really basic set up i took me about 3 hours to drop my car the first time ive ever done suspension on a civic. the thing you will need is 14, 12, 17mm sockets 14mm deep 17mm wrench basic tools you should allready have and a spring compressor if you dont have an impact gun.
is that bad that i dont have an impact gun i have just the hand ones
also is there a thread about how to do this and is there ways i can f up my car by doing something wrong?
that is mostly for shocks right and also would that car be the same set up as my civic ek?
try this one too
https://honda-tech.com/zerothread?id=1078663
same basic set up as yours instead of putting the coilover sleves on put your springs in. there is pretty much nothing you can **** up on the only thing i can think of is cross threading a bolt or loosing one but dont even worry about that its really easy. since you dont have an impact gun your gona need a spring compressor you can rent one at kragen. and compressing the stock spring will be the hardest part. you wont need to compress your new spring as it is shorter.
Here is a step by step on the proper way to lower your car (w/o pics)...
https://honda-tech.com/zerothread?id=1278794
civicmanyep
Suspension & Brakes
Jan 10, 2012 12:00 PM
