VAFC 2: Types of Vtec
Old Jun 22, 2005 | 06:13 PM
ShortBusTechnologies's Avatar
Default VAFC 2: Types of Vtec
I searched.. yes I did. No answer. maybe I didn't describe the search but I did it. So here goes.
The only reason I installed the VAFC 2 AGIAN was to be able to set the vtec crossover at a higher setting so I would not be in vtec the whole time on my road trip. Now, I'm just wondering tho (since partially bored and interested) what the different types of vtec do. There are 3 types: HIGH, MEDIUM AND LOW RPM selections. What do each effect. Does the HIGH setting set default corrections for high rpm? Etc?
Old Jun 23, 2005 | 04:05 AM
EE_Chris's Avatar
Default Re: VAFC 2: Types of Vtec (ShortBusTechnologies)
Pg. 49 of the Instruction Manual answers your question.
Old Jun 23, 2005 | 08:33 AM
Default Re: VAFC 2: Types of Vtec (EE_Chris)
I have the manual. And I have looked it up on that page. Still doesn't make sense to me. I mean, if you set the vtec to 5600 then its in all the vtec set points. High, med. and low. High is from 3000 to 7000. Med. form 3000 to 6000 and low is from 2000 to 6000. Hows that help?
Old Jun 23, 2005 | 06:05 PM
stumpyf4's Avatar
Pick the one that best suits the air/fuel correction range you're gonna use.
Old Jun 23, 2005 | 06:49 PM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShortBusTechnologies &raquo;</TD></TR><TR><TD CLASS="quote">I searched.. yes I did. No answer. maybe I didn't describe the search but I did it. So here goes.
The only reason I installed the VAFC 2 AGIAN was to be able to set the vtec crossover at a higher setting so I would not be in vtec the whole time on my road trip. Now, I'm just wondering tho (since partially bored and interested) what the different types of vtec do. There are 3 types: HIGH, MEDIUM AND LOW RPM selections. What do each effect. Does the HIGH setting set default corrections for high rpm? Etc? </TD></TR></TABLE>
I am lost....why would you be in VTEC your whole trip if stock vtec is 5500.....(give or take)?
Old Jun 23, 2005 | 08:44 PM
spectacle's Avatar
Default Re: VAFC 2: Types of Vtec (specv5150)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">I am lost....why would you be in VTEC your whole trip if stock vtec is 5500.....(give or take)?</TD></TR></TABLE>
B16 tranny+90mph = VTEC @ 5500rpm
Old Jun 24, 2005 | 12:13 AM
Default Re: VAFC 2: Types of Vtec (spectacle)
Because I have a GSR. 80 mph in 5th = 4000 rpm. 100 mph in 5th = 5000 rpm. Going to AZ. I have a tendency to go fast. VETC in my car is 4950 rpm (give or take). If I am going over 100.. then I am in vtec. I am not about to go to AZ from CA at 80. Most of the time I go over recommended. Just wanted vtec to not even be close. For those short sprints.. I won't be in vtec a 5600... at least not for long.
Old Jun 25, 2005 | 07:36 AM
LSVTEC 91 Civic's Avatar
Banned
Wow, it won't hurt you to be in VTEC for small "sprints" at a time. It might even be good for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShortBusTechnologies &raquo;</TD></TR><TR><TD CLASS="quote"> Just wanted vtec to not even be close. For those short sprints.. I won't be in vtec a 5600... at least not for long. </TD></TR></TABLE>
Hyaboosta
Oct 13, 2004 09:24 AM
South Bay Surfer
Oct 3, 2003 11:49 PM
civictypenos
Aug 25, 2003 05:29 PM
civictuned
Aug 1, 2003 04:36 PM
NeXtLeVeL_TyPe_R
Nov 13, 2001 04:05 PM
