Quick Help-- Tore Head Apart, Car Won't Start
Old Jun 22, 2005 | 04:21 PM
FullEffect256's Avatar
Default Quick Help-- Tore Head Apart, Car Won't Start
Well I overreved so i took the head apart, fixed the broken valve, and put it all back together, it starts up fine on the first try w/ a wierd on and off buzzing sound coming from the engine... also a little smoke coming from exhaust manifolds... so i shut it off...topped it off w/ some fluids and try again
when i try to start it, nothing happens, it just sounds like the radiator fans get turned on or something when i turn the key(could just be the starter spinning freely... i took the valve cover off to see, timing chain is still on, everything looks good... go to try again to see if **** spins when i start the key...nothing, the crank isn't turning... what could be the cause of this??? you think it's a dead battery? some kind of safety feature for something that went wrong?.... please any help is appreciated...thanks a lot guys
Old Jun 22, 2005 | 05:31 PM
Default Re: Quick Help-- Tore Head Apart, Car Won't Start (FullEffect256)
Okay, i think it has something to do w/ the security system... it's not letting me start the car, and i think it's because of a short somewhere...any ideas?
Old Jun 23, 2005 | 03:13 AM
pon55's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FullEffect256 &raquo;</TD></TR><TR><TD CLASS="quote">Well I overreved so i took the head apart, fixed the broken valve, and put it all back together, it starts up fine on the first try w/ a wierd on and off buzzing sound coming from the engine... also a little smoke coming from exhaust manifolds... so i shut it off...topped it off w/ some fluids and try again
when i try to start it, nothing happens, it just sounds like the radiator fans get turned on or something when i turn the key(could just be the starter spinning freely... i took the valve cover off to see, timing chain is still on, everything looks good... go to try again to see if **** spins when i start the key...nothing, the crank isn't turning... what could be the cause of this??? you think it's a dead battery? some kind of safety feature for something that went wrong?.... please any help is appreciated...thanks a lot guys</TD></TR></TABLE>
Try turning the motor by hand! You may have screwed a piston!!!!!!!!!!!!
OldskoojdmDA9
Feb 1, 2010 04:13 PM
TheHooded_Mike
May 19, 2006 03:50 PM
jDm-Ek9
Jul 22, 2005 01:23 AM
lowblazin
Nov 25, 2003 10:00 AM
