is a 99 accord 2 dr adn 4dr frotn end the same????
hi, i was wondering if the 99 accord 2dr and 4 dr frotn ends are the same or not, my parents go int oa acedent with the car and i need to know if the 4dr hood will fit ont he v6 coupe.. same with the fenders and bumper, thanks in advance...
for the 5th gen cars the front end was 3" longer if you had a V6. Not sure if it is the same for the 6th gen cars
the 6th gen coupe and sedan front ends are not interchangeable
the v6's are the same body as the i4's I'm pretty sure
its a 6th gen (98-02)....im pretty sure its a different front end coupe vs. sedan, and 4cyl vs 6cyl might have been a tad bit different
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 05 S2K Stoner »</TD></TR><TR><TD CLASS="quote">idk if this is a 5th or 6th, its a 99 so whatever that is....</TD></TR></TABLE>
6th gen
6th gen
https://honda-tech.com/zerothread?id=1163719
looks pretty clean in my opinion, i'd definitely do it if i had the money and time
ok so as i asked does the dr hood fit a 2 dr coupe?? whats the dif between them? please can i have a factual answer please, thank you
It will fit. You'll just have gaps. The hood should latch and all. Theres just a little bit of overhand or shortage for whichever converiosn you're doing. The coupe hood will be a little shorter as far as how long it hangs over.
Adding coupe fenders to the mix of coupe front bumper and hood should finish it cleanly.
sepetinswenze
May 14, 2015 07:30 PM
pepeotf45
10
Nov 28, 2008 08:20 AM
