Turbo manifold project
So I started my turbo manifold by doing the flange. 100% self made using a bench drill and a angle grinder.
More pics to follow as project continues.
Modified by Flashmn at 9:17 AM 6/24/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">holy ****! ur crazy!!</TD></TR></TABLE>
How so? :D
How so? :D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn »</TD></TR><TR><TD CLASS="quote">Yup, and cheap too
And that is the best part
</TD></TR></TABLE>And that is the best part
What type of press do you own and whats the thickness of the flange? What type of hole saw did you use?
I have a 3/4 hp 12 inch press and even with a new bimetal hole saw and lubrication, cuts through any mild steel thicker then 3/8th takes forever and a day. I would get upset doing it 4 times over and end up taking it to a mill with the type of press the average person has.
Looks cool so far
Looks cool so far
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">it looks like a non-vtec D-series head to me.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">my guess goes to either a AE92 or a 1.6slx head.. most likely the ae92</TD></TR></TABLE>
Yup, Toyota Corolla 4A-F head.
so what kind of turbo will you be using???, i think you can also use an additional injector controller just install 4 injectors to handle the boosted part of the rev range....
I dont know 100% sure what turbo yet, my friend is selling a T28 Garrett from a Diesel VW/Audi, the turbine side is relatively small, but should provide enough air to 200hp. Interesting thing that 4 injectors.. However, wouldnt it be the same if I installed EFI? Just a very basic efi setup.
Or I could use a single injector/jet (N2O fogger etc) to inject fuel before the plenum under boost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">What type of press do you own and whats the thickness of the flange? What type of hole saw did you use?</TD></TR></TABLE>
8mm thick, holesaw was an el cheapo "Magnum" one from the local hardwarestore, took maybe 5min per hole. The drill was a Rexon 250A, http://www.rexon.net/product/european/dp-250a.htm
Ok I managed to ruin the flange royally, but funny thing is, I have no idea why it went like that. Used normal wire and argon gas
Ok, thats a small test piece I did, weld looks fairly ok...
Now I do the manifold, and it does that!
Penetration in the first weld was good, could see a mark on the other side of the tube, on the manifold, well.. yes theres some, but it looks like bird droppings!
....not to mention whats up with that brown residue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Clean it with acetone. The flange is fine yet, just grind it down.</TD></TR></TABLE>
hahahaha, yeah you should see how warped it is now.... you can see it curve
Gas _should_ be ok. Same **** happened with another bottle.
I had the settings on max, I was shooting through the pipe part, but it wouldnt stick to the flange. I played around with power and wire feed settings, but it didnt work out. Gotta try to take a grinder to the flange and see if I can salvage it, then clean it up thoroughly and try again.
