Head Unit: display, but no sound
Old Jun 22, 2005 | 12:32 PM
HedgeCore's Avatar
Default Head Unit: display, but no sound
I have a cheap Dual HU... it powers on, but there's no sound coming out of it and the display seems dim (I don't have any basis for comparison). I called Dual tech support, and the guy suggested that I run my ground to the battery. I just read the FAQ on here, and it suggested against that in most cases. The Dual tech guy said that it sounds like I'm not getting enough power and running the ground to the battery will take care of that. Does this sound right? And if so, where should I start looking in a 95 Honda Civic for a space to run the wire through?
Old Jun 22, 2005 | 12:54 PM
philosofy1's Avatar
Default Re: Head Unit: display, but no sound (HedgeCore)
dont wire anything to the battery. double check your wiring to the speakers, and make sure you wired the power right.
Old Jun 22, 2005 | 05:52 PM
madcrossover's Avatar
I also had that problem with my unit at one point (Pioneer). Then I decided to connect the blue remote wire to the power when you turn the key on and it worked, so you could also try that. If your unit has the remote "Blue" wire.
crazyboy
Audio / Security / Video
Oct 31, 2010 08:38 PM
tzenisj
Mar 19, 2004 10:31 AM
JMX
20
Mar 3, 2004 11:30 AM
Tad
Nov 29, 2003 12:10 AM
EBP_SI
Jul 10, 2002 09:13 PM
