Are Gsr cams safe for a allmotor setup?
Old Jun 22, 2005 | 12:31 PM
Wesb18DB8's Avatar
Default Are Gsr cams safe for an allmotor setup?
i guess all you need to know is that the compression is 11.68..thanks
Modified by Wesb18DB8 at 7:48 PM 6/22/2005
Old Jun 22, 2005 | 02:13 PM
Padawan's Avatar
Darth ModerVader
Default Re: Are Gsr cams safe for a allmotor setup? (Wesb18DB8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wesb18DB8 &raquo;</TD></TR><TR><TD CLASS="quote">i guess all you need to know is that the compression is 11.68..thanks </TD></TR></TABLE>
If you're asking whether you can run GS-R cams with a C/R of 11.7:1, then the answer is yes. I'd suggest some method of tuning with that amount of compression though.
Old Jun 22, 2005 | 03:58 PM
Yambor's Avatar
Default Re: Are Gsr cams safe for a allmotor setup? (Padawan)
you can run stock gsr cams with that static cr, yet naturally you will not put out the power that you probably want unless you upgrade your cams to that of skunk2 stage 1 or similiar ctr profile.
Yambor's Avatar
Default Re: Are Gsr cams safe for a allmotor setup? (JH4DC4-2GSR)
Also what is your setup?
Old Jun 22, 2005 | 06:49 PM
LSVTEC 91 Civic's Avatar
Banned
Safe.. yes. But too small, go for at least a CTR profile.
Old Jun 22, 2005 | 08:02 PM
Wesb18DB8's Avatar
B18c1, jdm itr pistons, pnp head, 3 angle valve job, milled .020, skunk2 IM, OBD1 conversion tuned with uberdata, USDM Type R tranny, Exedy stage 2 3 puck(thick disk), in the process of getting my Dynamic Racing header(Peak Performance), es oval muffler, dynomax resinator, and 2.5in pipe...just waiting for the flange and donut,...umm..i think thats about all....
Modified by Wesb18DB8 at 12:20 AM 6/23/2005
Modified by Wesb18DB8 at 12:46 AM 6/23/2005
cdfran
May 19, 2008 07:13 AM
cdfran
May 10, 2008 06:03 PM
VTECcnIT
Apr 13, 2006 03:34 PM
ScottFern
14
May 19, 2005 09:37 AM
SnkyPY
Feb 25, 2004 01:28 PM
