Help ASAP on 99-00 front end conversion
Old Jun 22, 2005 | 12:09 PM
GetSmoked's Avatar
Default Help ASAP on 99-00 front end conversion
right now im doing the conversion and i removed most of the bolts. the ones i cannot find are the bolts on the bottom of the fender. do you need to remove the fender lining or side skirts to remove the fender or lining? i tried to take the side skirts off but it wont budge. thanks for any help you can give me.
Old Jun 22, 2005 | 01:16 PM
96CivicBoostCoupe's Avatar
Default Re: Help ASAP on 99-00 front end conversion (GetSmoked)
for th fender there should be 1 screw under the a-piller when you open the door, 3 under the hood, 1 by the headlight and 1 or 2 under the sideskirt. to remove the side skirt, remove the screw in the rear fender well, there might be one on the front, and there are 3 plastic clips on the bottom, then the side skirt slides foward and pulls straight off.
Old Jun 22, 2005 | 03:12 PM
Shaun's Avatar
Default Re: Help ASAP on 99-00 front end conversion (96CivicBoostCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96CivicBoostCoupe &raquo;</TD></TR><TR><TD CLASS="quote">for th fender there should be 1 screw under the a-piller when you open the door, 3 under the hood, 1 by the headlight and 1 or 2 under the sideskirt. to remove the side skirt, remove the screw in the rear fender well, there might be one on the front, and there are 3 plastic clips on the bottom, then the side skirt slides foward and pulls straight off.</TD></TR></TABLE>
Old Jun 22, 2005 | 06:15 PM
GetSmoked's Avatar
Default Re: Help ASAP on 99-00 front end conversion (Shaun)
thanks there was 2 near the sideskirt. too bad i pryed and broke all the plastic screws because i didint know how to take them off.
aystupet
Paint and Body
Jul 10, 2013 12:48 PM
Khanster
Feb 3, 2009 10:57 PM
00b18ek
Jun 24, 2008 10:43 AM
gcturismo
Jan 20, 2008 05:21 PM
slvrDC4
Oct 26, 2007 10:03 PM
