Parts of PRELUDE engine
Old Jun 22, 2005 | 11:18 AM
xxaznboystyl3xx's Avatar
Default Parts of PRELUDE engine
HI i am wondering about all the parts under the hood in a prelude vtec dohc and what they do
Help me add more to the list and of what they do
i am missing any details about a part and got the wrong info plz correct me
i am a new to cars and just want to know more plz help
please include pictures or websites that can help me understand
H22a engine - 190 hp, torque?, compression?, weight?,
Vtec- is this a chip or part of the head unit? can anyone show me a link with a picture of it
Block-bottom of the engine
Head gasket - keep oil from leaking out, if thicker can decrease compression
Pulley- ??? increase hp
pully belt- ???
intake- bring cold air into the engine, increase hp
Header - increase hp, attaches to what? header to somethign to downpipe to something to muffler
Distributer- charges the battery
Starter - starts the engine
Clutch - grabs the transmission into gear?, can increase hp and torque
Flywheel - turns the cam shafts, allow rpms to go up faster
clutch disks - ????
cam shafts - makes pistons go up and down, the longer the more torque
Input shaft- ????
rod - attaches the cam shafts to the pistons
pistons - if the head is flat it can decrease compression
sparkplugs - ignite the gas
ignition- ??????????
master slave - something with the clutch?
intake manifold - ????
manual transmission - ??????
ecu - controls how much gas is used? hp?, torque?
plz add more to the list and help add more info to these parts
Old Jun 22, 2005 | 11:36 AM
BeanBag64's Avatar
Default Re: Parts of PRELUDE engine (xxaznboystyl3xx)
H22a1 engine - 190 hp, 158 ft/lbs of torque
Vtec- (Variable valve Timing and lift Electronic Control) Its not part of a head unit because when I turn off my radio, I can still hear it above 5k RPM. Just go to HowStuffWorks.com and look it up.
I give up! Frankly, you know less than nothing. It would have been so much better if you left a blank after the word. The first couple ones were funny, but after that I started getting angry. You really just need to look this stuff up. Google everything.
Spark plugs is the only thing you got semi-right.
Maybe someone with more patience can finish this. There is no flame suit that can handle what you may get.
BTW How old are you?
Modified by ofthesun93 at 12:48 PM 6/22/2005
Old Jun 22, 2005 | 11:48 AM
speedracer9k's Avatar
Default Re: Parts of PRELUDE engine (ofthesun93)
wow, that post just made my day!!! haha
Old Jun 22, 2005 | 11:51 AM
xludexgenx5's Avatar
(depends on if its JDM or not, US & JDM have diff Comp)
(a house phone & its called VTECH)
(the thing pistons go in.)
(seals the head to the block,)
(aftermarket ones can reduce drag)
pully belt- ???
(belt that goes around the pulley)
(the pipe & filter that connects to the T/B, which the motor sucks air through)
(Aftermarket Headers generally increse HP, connects to the cat,then resonator,then muffler, if its stock. Only turbo cars call it downpipes.)
(Distributes SPARK to the SPARK plug wires)
(congrats )
(no. does not increase hp & tq, a lighter one may free up some drag, or a better gripping one can get the power to the ground better.)
(bolted to the crank, this is what the clutch bolts to and grabs onto.)
(They open & close the valves)
Input shaft- ????
(of?)
( connects pistons to the crank )
(ignites the mixture within the combustion chamber of Fuel +Air)
(WTF master slave? its either Master or Slave not both)
( where air goes after the intake, and divides into each cyclinder* careful YOU may blow the welds on it.)
(from mexico, uh self explainitory if its not automatic then its manual)
(controls the functions of the motor, such as fuel, timing, blinker fluid , etc..)
hmm I hope I'm somewhat correct, like a quiz at school. entertaining for a bit..next time look in the faq section, lucky for you I'm bored.
Old Jun 22, 2005 | 11:56 AM
BeanBag64's Avatar
Default Re: Parts of PRELUDE engine (xludexgenx5)
Master Slave is a role playing sex game...
Old Jun 22, 2005 | 11:57 AM
lol oops I forgot that one.
Old Jun 22, 2005 | 12:02 PM
optikal_blitz's Avatar
yea the first thing i thought when i was about to respond was "quiz.."
You're correct..
to elaborate on the 'manual transmission'
it is a Planetary Gearset (google it) that allows the motor to use the same amount of revolutions (RPM) of the flywheel to increase the vehicle speed.
its kind of like this::
| | | | | <-- Google: "Gear Ratio"
1 2 3 4 5
The difference between manual and auto is that YOU select the gear through every round of acceleration vs a hydraulic system (torque converter) controlled by the ECU selecting the gears for you.
Glad you wanna learn, but this is all stuff you can easily learn through context when you search
for all the people who have anything negative to say-- you gotta start somewhere
bad-monkey's Avatar
don't forget the blinker fluid reservoir...
yeah, wow.
this is what happens when people learn the basics of ICE's from "tuner magazines" and parts ads.
Old Jun 22, 2005 | 12:21 PM
Hawkze_2.3's Avatar
Good Lord! I was once like you and knew nothing, but I did some RESEARCH and found out the answers myself instead of asking for it to be spoon-fed to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxaznboystyl3xx &raquo;</TD></TR><TR><TD CLASS="quote">cam shafts - makes pistons go up and down, the longer the more torque
Not quite....
Old Jun 22, 2005 | 12:35 PM
Luder94's Avatar
Default Re: Parts of PRELUDE engine (Hawkze_2.3)
Everything you needed to know and buy....right here. Click on the "Performance" menu item:
http://www.kalecoauto.com/
Old Jun 22, 2005 | 01:05 PM
durand202's Avatar
Default Re: Parts of PRELUDE engine (Luder94)
You can learn alot from this https://honda-tech.com/zerothread?id=689805
Old Jun 22, 2005 | 01:43 PM
IHateJDM's Avatar
Default Re: Parts of PRELUDE engine (durand202)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xludexgenx5 &raquo;</TD></TR><TR><TD CLASS="quote">ecu - controls how much gas is used? hp?, torque?
LOL, I think my blinker fluid maps are messed up.
Since you are a noob, please also remember that neon/led lights (in any form), giant wings, body kits, hood scoops, z3 fenders, clear taillights, 5" exhaust tips, and stickers for parts you do not own will not help you go faster. Those parts only make your car look slower, and attract attention from theives.
BTW, search this site. You'll find the answer to anything you need to know that's honda related in the archives.
Old Jun 22, 2005 | 01:46 PM
5hif7's Avatar
Default Re: Parts of PRELUDE engine (IHateJDM)
WHAT?!?!? I was assured that the neon lights, 8' wing, and M4D TYTE stickers along with my coffee can exhaust added at least 569847362273849 hp....
Old Jun 22, 2005 | 07:49 PM
Oh snap, that reminds me...I've got to get my vtec fluid changed this weekend at the honda dealer.
This thread is as useless as the WNBA
Old Jun 22, 2005 | 08:31 PM
plikit's Avatar
good to see someone who wants to learn and isnt afraid to admit they dont know much about it. gotta start somewhere is right.
Old Jun 22, 2005 | 10:54 PM
RemerLex11's Avatar
Default Re: Parts of PRELUDE engine (plikit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by plikit &raquo;</TD></TR><TR><TD CLASS="quote">good to see someone who wants to learn and isnt afraid to admit they dont know much about it. gotta start somewhere is right. </TD></TR></TABLE>
seriously, but dont post questions like that here, or you'll get flamed. go to google or any search engine and you'll find a shitload of info by just reading
b1lightning
Feb 1, 2019 02:43 AM
B16b-EJ8
35
Nov 14, 2006 08:31 AM
WAFFLES
37
Aug 6, 2003 03:41 PM
Mr. Vapor
Oct 22, 2002 07:59 AM
