Which kind of Oil?
Old Jun 22, 2005 | 10:53 AM
J blunted's Avatar
Default Which kind of Oil?
I have a 95 Accord EX (auto) 140,000 miles. What Oil would protect and do the best 10W-30 or 5W-30? Thanks.
Old Jun 22, 2005 | 11:10 AM
alotawatts's Avatar
Default Re: Which kind of Oil? (J blunted)
In AZ ? I would use 10/30 year round !
Old Jun 22, 2005 | 11:52 AM
J blunted's Avatar
Default Re: Which kind of Oil? (alotawatts)
In my owners manual it says I may use 10W-30 in an area that never goes below 20F, well in Arizona its HOT, ju know, anyways the manual says 5W-30 is Preferred. But living in Arizona should I use 10W-30? Looking for the best protection/peformance. Thanks!
Old Jun 22, 2005 | 01:22 PM
tr3-2001SE's Avatar
I think Mobil 1 is hard to beat. You can get it at Sam club for less than $4 a quart and you can run it 8 to 10 thousand miles if your engine is in good shape. It also keeps the inside of your engine clean as a whistle. Great in my Honda Accord and Mazda Miata. Try it you'll like it.
Old Jun 22, 2005 | 06:17 PM
jb.'s Avatar
jb.
Default Re: Which kind of Oil? (tr3-2001SE)
in north carolina, i run 10w30 reg mobil in the spring and summer, and in the winter, i run 5w30 for my 95 accord
Old Jun 22, 2005 | 09:20 PM
cottonfamily05's Avatar
Default Re: Which kind of Oil? (jbkiksass69)
I am in Pennsylvainia and have 132K on my 93 what is a good 1 for me? GTS High Mileage or Syntetic??
Old Jun 22, 2005 | 09:22 PM
RiceRocketDave's Avatar
Default Re: Which kind of Oil? (ejc3110)
I use 10W-30 Royal Purple and it is by far the best stuff I have ever used.....Even better than Mobil-1
Old Jun 22, 2005 | 09:23 PM
XenonKiller99's Avatar
Default Re: Which kind of Oil? (ricerocketdave)
Yeah, 10/30
Old Jun 22, 2005 | 09:28 PM
NAiL05's Avatar
If your engine is old i wouldnt recommend synthetic. It isnt going to do you much good. You might as well save the money and buy normal oil.
I use 10W30 year round in Texas.
Old Jun 23, 2005 | 06:16 AM
satterfield's Avatar
I use O-30 gc in my 1996 accord vtec -- satterfield
Old Jun 23, 2005 | 10:22 AM
13lue's Avatar
Default Re: (satterfield)
How much is for royal purple 10/30? I use Mobil1 10/30 synthetic year round for my 01 accord v6
Old Jun 23, 2005 | 11:43 AM
pa_itr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricerocketdave &raquo;</TD></TR><TR><TD CLASS="quote">I use 10W-30 Royal Purple and it is by far the best stuff I have ever used.....Even better than Mobil-1</TD></TR></TABLE>
Do you have UOA's to back that up? Or are you just going on "how smooth my engine ran!" ???
pa_itr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tr3-2001SE &raquo;</TD></TR><TR><TD CLASS="quote"> I think Mobil 1 is hard to beat. You can get it at Sam club for less than $4 a quart and you can run it 8 to 10 thousand miles if your engine is in good shape. It also keeps the inside of your engine clean as a whistle. Great in my Honda Accord and Mazda Miata. Try it you'll like it.</TD></TR></TABLE>
Mobil 1 has a tendency to thin out after around 2,000 miles and become a 20 weight oil. Hardly something I'd want in my engine for 8k.
Old Jun 23, 2005 | 11:46 AM
pa_itr's Avatar
Mobil 1 synethic is the only TRUE synthetic you will find on the shelves at wal mart. Everything else is a blend marketed as a synthetic and at synthetic prices (you can thank Castrol for that sort of marketing crap).
I use Mobil 1 synthetic in my 264k accord but I still change it out every 3k due to the problems mentioned in my prior post; thinning.
I use amsoil in my Type-R. It's more expensive but it's probably the best oil you can buy right now. If you go to bobistheoilguy.com, you can read more.
Old Jun 23, 2005 | 08:58 PM
Default Re: (pa_itr)
For one after using it (Royal Purple) for about 30k miles and having an extremely dirty motor before, it almost looks clean enough to eat off of now. Plus my motor did run much smoother with it vs. Mobil-1. Plus the gas mileage went up dramatically.
Old Jun 24, 2005 | 08:29 AM
pa_itr's Avatar
Default Re: (ricerocketdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricerocketdave &raquo;</TD></TR><TR><TD CLASS="quote">For one after using it (Royal Purple) for about 30k miles and having an extremely dirty motor before, it almost looks clean enough to eat off of now. Plus my motor did run much smoother with it vs. Mobil-1. Plus the gas mileage went up dramatically. </TD></TR></TABLE>
Dunno how you can attribute that to an oil. Gas mileage is dependent on a lot of things and oil is probably has the least effect. Weather, humidity, tire pressure, driving habits, etc etc, can all be attributed to a difference in gas mileage.
How do you know you had a dirty motor? Have you torn it down and gone inside? Sorry, but there's something to be said about an oil that has purple dye in it and comes out brown/black.
I also believe you were justifying the cost of Royal Purple with your statement of "it runs so much smoother". Explain to me how oil will make an engine run smoother.
Old Jun 27, 2005 | 01:48 PM
alotawatts's Avatar
And an oil making the outside of the engine clean would be pure Magic ... would'nt it ?
escape2me
Aug 5, 2006 01:20 AM
aleks77
Jun 24, 2005 09:26 PM
phat_saini
Aug 21, 2004 06:22 PM
diyer
Jun 18, 2004 07:44 AM
DrewQ1
Dec 20, 2003 11:24 AM
