Need advice on this type of TIG welder.
Old Jun 22, 2005 | 10:42 AM
julio_bOostamante's Avatar
I'm a Jackass
Default Need advice on this type of TIG welder.
I found this on ebay and i know its no miller, but for the am ount of money it costs if it works it works.
http://cgi.ebay.com/ws/eBayISA...&rd=1
i have had some experience with a miller syncrowave at school but im in no position to spend that much cahs right now. i just want something for the garage sp i can fab up my own IC pipes DP pipes and other miscelaneous projects like my modified Starion IC.
thanks in advance.
Julio
Old Jun 22, 2005 | 10:58 AM
beepy's Avatar
Default Re: Need advice on this type of TIG welder. (julio_bOostamante)
The major drawback of a DC TIG is that you cannot weld aluminum. IMO, it's no better than a MIG, and MIGs can weld aluminum if you have a spool gun, argon and patience.
Modified for correct info, yo.
Modified by beepy at 8:46 PM 6/22/2005
Old Jun 22, 2005 | 11:21 AM
richg's Avatar
Default Re: Need advice on this type of TIG welder. (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">The major drawback of an inverter TIG is that you cannot weld aluminum. IMO, it's no better than a MIG, and MIGs can weld aluminum if you have a spool gun, argon and patience. </TD></TR></TABLE>
This is a completely incorrect statement. The fact that it is an inverter does not mean it cannot weld aluminum. In fact, inverters can actually weld aluminum better than traditional transformer style machines.
The problem with that welder (other than the fact that its likely a POS) for aluminum is that it is DC only. You need a TIG which can do AC.
rich
Old Jun 22, 2005 | 11:32 AM
I'm a Jackass
Default Re: Need advice on this type of TIG welder. (richg)
thanks for the info guys. i really appreciate it. i guess i will get a lincoln135 mig or just save up. who knows.
MidShipCivic
Welding / Fabrication
Feb 15, 2008 03:12 PM
gulftiresinc
Mar 23, 2007 09:50 AM
1997IntegraGS
Jan 19, 2007 06:42 PM
bluebird
10
Oct 15, 2004 07:28 PM
Evil EG
Sep 10, 2003 07:27 PM
