D-series: What size/thread pitch are the oil pan studs?
I forgot to check last night when I was working on the car
I want to pick up a single die (ie tap & die) to chase the external threads on the studs that hang out of the bottom of the block (where the oil pan connects to the block)
I *think* they're 10mm, but can anyone confirm the size as well as the thread pitch? (ie 1.25 vs 1.50)
Thanks. I want to go buy this at lunch today and forgot to bring the stud with me, etc.
Update: Someone on the crx forum posted the answer I needed.
Thanks anyways...
10mm is the size of the head of the bolt or nut..
The actual size of the stud is 6mm x 1.0mm pitch..
Thanks anyways...
TAG
Jun 22, 2005 11:08 AM
