CRX Different Model Transmissions??
Old Jun 22, 2005 | 03:19 AM
88crxhfb16's Avatar
Default CRX Different Model Transmissions??
I have a 1988 CRX DX.
Will an HF Transmission bolt up?
are there any differences.
Old Jun 22, 2005 | 03:34 AM
crx_88_si's Avatar
bolt up just fine. use an 88 though
88, 89, 90+ all use different clutches.
88 has a smaller flywheel and 21 spline input shaft on the tranny.
89 has a smaller flywheel and 20 spline input shaft
90-91 has a larger flywheel and 20 spline input shaft.
my #'s may be off but the same idea applies.
Old Jun 22, 2005 | 03:49 AM
88crxhfb16's Avatar
Default Re: (crx_88_si)
yes it is from an 88 hf so i should be set. Now how hard is the swap?
Old Jun 22, 2005 | 07:28 AM
crx_88_si's Avatar
its not the easiest thing in the world, but if u have replaced axles before than this isn't much more complicated.
- tranny mounts (dont forget to support engine w/ something!)
- starter
- clutch cable
- rev sensor
- speed sensor
- tanny bolts.
Old Jun 22, 2005 | 07:50 AM
bagpipe goatee's Avatar
i just thought i should mention this, since nobody else did. the hf tranny is one of the longest geared trannys you can imagine. this will completely kill your accelleration, but it will give you amazing gas milege.
Old Jun 22, 2005 | 01:47 PM
88crxhfb16's Avatar
Default Re: (bagpipe goatee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">i just thought i should mention this, since nobody else did. the hf tranny is one of the longest geared trannys you can imagine. this will completely kill your accelleration, but it will give you amazing gas milege.</TD></TR></TABLE>
exactly why I want to do it. I drive 150 miles everyday. highway 5th gear miles.
HF 5th 70mph 2100 rpm
DX 5th 70mph 3200 rpm
MPGIan
Mar 29, 2011 08:20 PM
jdmb20boi
11
Jun 12, 2008 09:27 PM
Gant
Mar 11, 2005 07:11 PM
Project_ED8
Mar 19, 2004 02:21 PM
xmd
Dec 8, 2003 05:37 PM
