car dies right after start up......
Old Jun 22, 2005 | 12:33 AM
xd69's Avatar
Default car dies right after start up......
my car has trouble starting up. when it does start up it dies after about 1 minute. my rpms just fall down even if i give it gas. i start it bakc up and it will run for a little bit again and then just die. could it be my dizzy???
Old Jun 22, 2005 | 06:53 AM
Kool305's Avatar
Default yo
yeah could be timing related...any check engine lights?
also check the main relay...this used to happen to me...
Old Jun 22, 2005 | 09:25 AM
xd69's Avatar
Default Re: yo (Kool305)
only throwing a code 14(iacv). also, when i drive the car, my rpm needle start to jump all over the place. even now that the car is fucked up, when i rev it passed 3k the needle starts to jump crazy.
Old Jun 24, 2005 | 09:42 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: yo (xd69)
verify that you have the correct plug plugged in for your iacv. you may need to pull it off and have it cleaned.
Old Jun 28, 2005 | 02:00 PM
5thGenFanatic's Avatar
Default Re: car dies right after start up...... (xd69)
i had the same problem in my integra last year...when i would drive it it would hit 2500 and buck oike i hit the rev limiter...then would stall when warm....it was my map sensor...even tho it threw a code 14 like yours ..it was the map sensor..check to make sure it is correct/ getting vacuum,connected or just a plain bad sensor
dubzz24
Mar 2, 2007 09:14 AM
1sikhatch
Dec 19, 2005 05:32 PM
Dancing is Forbidden
12
Jul 30, 2005 01:34 PM
DragInteg
Apr 21, 2004 12:09 PM
