94 civic high idle
Old Jun 22, 2005 | 12:23 AM
civicpower94's Avatar
Default 94 civic high idle
i got a 94 civic 5 speed manual just changed to 1.6 cylinder head and i have high idle any idea help would be appreciated and whats the proper wiring for oxygen sensors cause my 4 wires came out of the plug. thanks
Old Jun 22, 2005 | 01:35 AM
_Cyclone_'s Avatar
Default Re: 94 civic high idle (civicpower94)
You're going to have to check everything over for vacuum leaks.
Old Jun 22, 2005 | 03:58 AM
JDM-EJ1's Avatar
Default Re: 94 civic high idle (CycloneBlue_1.6EL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL &raquo;</TD></TR><TR><TD CLASS="quote">You're going to have to check everything over for vacuum leaks.</TD></TR></TABLE>
Yes, and how how is it idleing?
Old Jun 22, 2005 | 04:19 AM
_Cyclone_'s Avatar
Default Re: 94 civic high idle (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, and how high is it idleing?</TD></TR></TABLE>
Old Jun 22, 2005 | 09:36 AM
its idle at like probably at 1000-1500 not sure cause i dont have tach. but by listening to the engine is sound like is at 1000-1500 any ideas and how do i check for leak and where thanks guys
Old Jun 22, 2005 | 09:37 AM
JDM-EJ1's Avatar
Check vacuum lines, your IACV, idle adjustment screw. All these play a vital role in your idle.
Old Jun 24, 2005 | 05:10 PM
where is the plug for scanner located and what is iacv and where is that located? thanks
Old Jun 24, 2005 | 05:11 PM
vacume hoses on what the idle control valve or on idle control motor ?
Old Jun 24, 2005 | 11:49 PM
_Cyclone_'s Avatar
Check all the vacuum connections (there's not that many on a PGMFI Honda). You could take your intake off and seal your hand (or something) over the throttle body and see if it still runs, then you know you have a leak.
Old Jul 13, 2005 | 04:50 PM
Default Re: 94 civic high idle (_Cyclone_)
alright i fixed the problem it was the idle control valve on the bottom of the trottle body, but i got another one problem . My rpms are going up and down i replaced the throttle body gasket cause thats where the leak was still doing the same **** up and down etc. i replace the eacv still the same **** any ideas. thanks
darkstar90
Apr 26, 2007 10:57 PM
kixcrx
15
Jan 9, 2007 12:52 PM
alghafat424
Nov 13, 2006 01:29 AM
jerbear!
May 9, 2005 11:00 AM
eg6nes
Feb 21, 2005 03:57 PM
