non-vtec distributor on a vtec motor....
Old Jun 21, 2005 | 11:37 PM
mdj_ge's Avatar
Default non-vtec distributor on a vtec motor....
What would happen if this occur.... ??????
Old Jun 22, 2005 | 07:45 AM
No_Fear's Avatar
Default Re: non-vtec distributor on a vtec motor.... (yangja)
probably will not start th engine.
Old Jun 22, 2005 | 11:40 AM
maxrpm's Avatar
If you r refering to the b18 than the ls distributor one of the leg needs to cut to work on the gsr head. Once that is done the motor should not have a problem starting.
Old Jun 22, 2005 | 02:47 PM
dumpeDc2's Avatar
I'm a Jackass
Default Re: non-vtec distributor on a vtec motor.... (maxrpm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxrpm &raquo;</TD></TR><TR><TD CLASS="quote">If you r refering to the b18 than the ls distributor one of the leg needs to cut to work on the gsr head. Once that is done the motor should not have a problem starting.</TD></TR></TABLE>
seen it working in action my self
Old Jun 22, 2005 | 03:14 PM
notstock93's Avatar
I had this setup for about a month, works fine. The leg needs to be cut to clear the VTEC solenoid.
Old Jun 22, 2005 | 06:08 PM
slomofo's Avatar
GDD Member
Might as well cut two legs off, since only one leg will bolt on. (Weight savings, to make you go faster )
nomotor
Oct 3, 2006 12:36 PM
Fastwhip
Apr 11, 2006 12:58 PM
accrdpusha
Nov 8, 2005 02:20 PM
Scubster
Aug 13, 2004 03:30 PM
Bnjmn
Mar 1, 2002 04:03 PM
