Hiding Nitrous Poll
ahh nitrous.... good times. If you have a sneaky pete/incognito kit... maybe you can fit it there. A 10 lb bottle.. ain't gonna happen.
Last summer I had my ZEX bottle in a gym bag with the bottom cut out. And filled it with laundry.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDrew »</TD></TR><TR><TD CLASS="quote">
Last summer I had my ZEX bottle in a gym bag with the bottom cut out. And filled it with laundry. </TD></TR></TABLE>
haha nice. how bout disguising it like one of those bazooka tubes. ya know the subs that are supposed to look like nitrous. how bout nitrous that it supposed to look like subs
my buddy had a box of 12's in the back of his rex that was otherwise gutted and had the bottle in the inside of the box. No one ever said anything since he was always bumping his ****. He never got hastled by the cops either since he had all of the lines hidden with black tape and covered in plastic wire loom. If you are going to do it go all the way dont half *** it.
yea... ur bottle is huge man... ain't gonna fit in the storage compartment. Even under the plastic its really shallow. Not to mention you need to have the bottle leaned properly for correct nitrous flow.
Buy a shitty sub... maybe a 12inch. Gut it completely. Except the facia.
Build an appropriate box that allows for the proper install angle. Also create a trap door or sorts covered by box carpeting.
Install an auto opener.
use some plastic loom stuff to cover the nitrous lines... will look like speaker wire.
Happy Hunting.
On a side note, hiding nitrous gets old. You use it once on someone and everyone calls you out etc etc. People will find out, it happens. I guess you can be hiding it because of the cops... I dunno
Happy Hunting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rednas »</TD></TR><TR><TD CLASS="quote"> If you are going to do it go all the way dont half *** it.</TD></TR></TABLE>
#1- thats what she said
#2 Who said anything about halfassing anything
#3 who died and made you ASE certified
#4 Why would i want subs. so i can go around <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rednas »</TD></TR><TR><TD CLASS="quote"> always bumping his ****. .</TD></TR></TABLE>
Bad Post
Bad Post
Battery box, gut some 4 guage and run the nitrous line threw, into the back of the block (like a ground), up threw the rear drivers side oil drain passage, and drill the head to have the nozzles under the valve cover. The nitrous solenoid will do fine in the oil pan if you seal them. Run hondata for the fuel side and activation and your set.
wow. if the bottle is in your ***, do you still use a bottle warmer?
sounds like a few of these posts are kind of retarded, in which case i think you gusy should probably put it inside the leather sest of your red veilside rx-7 while youre racing ja-rule. dont forget your LED purge valve.
otherwise...the gymbag is the best thing ive seen so far.
also...you can hide your bottle until youre blue in the face..but you have to hide lines (bottom of manifold) and hide solenoids (inside of old fake mechanical fuel pump housings)
no bottle warmer needed
i was thinking where the intake resonator box is, behind the bumper, its a zex kit so hide the box in there. then just cover the lines in wireloom and make it look like stock shinto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker »</TD></TR><TR><TD CLASS="quote">Battery box, gut some 4 guage and run the nitrous line threw, into the back of the block (like a ground), up threw the rear drivers side oil drain passage, and drill the head to have the nozzles under the valve cover. The nitrous solenoid will do fine in the oil pan if you seal them. Run hondata for the fuel side and activation and your set.
Are you kidding me
</TD></TR></TABLE>Are you kidding me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR »</TD></TR><TR><TD CLASS="quote">
Are you kidding me
thats what im sayin
Are you kidding me
</TD></TR></TABLE>thats what im sayin
u got that guys,u will be all set and no one will even kno,there all dum but will work on cops and maybe a dum *** hot rodder
Modified by Autoworks at 5:24 AM 6/24/2005
as I said in the 2nd post... gym bag is the best way.
-Line under carpet.
-Box hidden behind glove box
-other line hidden in loom
-TPS switch attached farther down the look than just right next to the sensor itself.
eh... nitrous is fun... but it gets old fast.
-Line under carpet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91whiteZCrex »</TD></TR><TR><TD CLASS="quote">i hide my nitrous bottle up my ***
haha
</TD></TR></TABLE>haha
thats what im sayin</TD></TR></TABLE>
I have seen it done. solenoid were under the dash and the lines ran into the back of the block under the intake manifold. I have been around for awhile.
