Suspension & Brakes Theory, alignment, spring rates....
how to stop the BUMP!
Old Jun 21, 2005 | 08:18 PM
mountaindewguy's Avatar
Default how to stop the BUMP!
ok, i got a 95 ex....its lowered slightly. i just put some 17's on it, with a gap where i can barely get 2 fingers between the tire and the fender. im running 205/40/17. now my problem is... its got agx struts, aerospeed coilovers. its always been a little bumpy, even set on a soft setting, but after i put on the rims, its like when i hit a bump, its a tight bump noise, but almost sounds like a rub. but its not rubbing, because theres nothing wrong with the tires or anything....anyone know where this noise is coming from?
Old Jun 22, 2005 | 12:41 PM
Default Re: how to stop the BUMP! (mountaindewguy)
Old Jun 22, 2005 | 12:59 PM
philosofy1's Avatar
you are actually rubbing. every time you rub its not always going to damage the tire or may never damage the tire. its not the tires so dont worry about the that, to avoid the problem, why dont you raise the car up alittle.
Old Jun 22, 2005 | 01:03 PM
nonsense's Avatar
what tires did you have on there before?
you now have a 3.2" sidewall as compared to say a 205/50-15 with a 4" sidewall. So you're going to feel the bumps more.
Or you could be rubbing ....
Old Jun 22, 2005 | 05:55 PM
Default Re: how to stop the BUMP! (nonsense)
ok i was rubbing, i put the tires at night, and drove it for a bit, and i didnt see it until today, the screw holding the bumper up next to the front tire broke......, so it was rubbing, thanks tho guys
Old Jun 27, 2005 | 08:04 AM
Earthworm Jim's Avatar
Try a smaller rim.
bopbop93030
Feb 2, 2009 02:43 PM
Soda Popinski
Nov 21, 2005 11:52 AM
Jaysun
13
Sep 9, 2003 11:23 PM
deviant1
Apr 12, 2003 12:23 PM
