computer chipping check list
Old Jun 21, 2005 | 08:16 PM
projectTeG's Avatar
Default computer chipping check list
ok, ive decided instead of buy hondata or the greddy blue box, i was going to learn how to chip my own ecu for either uberdata or chrome. i was wondering what all i need to accually get inorder to do all the work. and where i could pic these things up at
Old Jun 22, 2005 | 02:12 AM
projectTeG's Avatar
bump!
Old Jun 22, 2005 | 03:42 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (projectTeG)
http://www.pgmfi.org
uberdata.pgmfi.org
Read and you shall learn it all.
Old Jun 22, 2005 | 12:17 PM
projectTeG's Avatar
thanks
Old Jun 23, 2005 | 05:14 PM
boosted k20's Avatar
- 1K resistor at R54
- jumper wire at J1
-two 0.1uF Capacitors
(all above can be purchased at radio shack)
-74HC373 IC chip (can be purchased at jameco.com)
-28 pin DIP socket (ebay it)
-AT29C256 chip
Chip burner (willem enhanced chip burner is cheap and can be found on ebay) and a computer/laptop. another chip burner is the BURN1. u can buy it for 95 bucks on http://www.moates.net. u can also buy the entire chipping set which includes the resitor, caps, 28 pin dip socket, at29C256 chip, ZIF socket on http://www.moates.net
plus if u need to tune the car u will need a wideband O2 sensor ( YOU WILL NEED TO TUNE THE CAR cuz all basemaps in uberdata/crome will run rich as hell)
Old Jun 23, 2005 | 05:29 PM
projectTeG's Avatar
thanks...so i have to order these things on-line? could computer shops have this stuff?
Old Jun 23, 2005 | 05:50 PM
they wont have everything u need. best way to buy stuff is online
Old Jun 23, 2005 | 05:55 PM
projectTeG's Avatar
Default Re: (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">they wont have everything u need. best way to buy stuff is online</TD></TR></TABLE>
kool, thanks for the help....now its time to go see if i can do this, i hope its not that hard i might just end-up buying hondata for this motor. then learning the chipping/tuning side of the ecu's after.
Old Jun 23, 2005 | 09:17 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">kool, thanks for the help....now its time to go see if i can do this, i hope its not that hard i might just end-up buying hondata for this motor. then learning the chipping/tuning side of the ecu's after.</TD></TR></TABLE>
Make sure you practice on a junk ecu....
I would recommend looking into crome pro. Hondata is really not worth it IMO.
Old Jul 12, 2005 | 04:55 PM
xagix's Avatar
Default Re: (mtber)
What is an estimation on how much everything cost to chip ecu's ?
evilhatch2.0
Apr 30, 2006 07:57 AM
iH8RICERZ
Oct 23, 2004 11:10 AM
96_GSR
Jul 23, 2002 08:33 AM
Eg6_JDM
Mar 14, 2002 09:34 AM
