which axles/int shaft for b20 swap with ys1
Old Feb 12, 2002 | 11:07 AM
freud's Avatar
Default which axles/int shaft for b20 swap with ys1
i believe i will be using the 90-93 integra axles and intermediate shaft for this but i wanted to double check with you guys. is this the best solution or will i have a better match up by mixing and matching various kinds?
Old Feb 12, 2002 | 01:49 PM
RyanR's Avatar
Default Re: which axles/int shaft for b20 swap with ys1 (freud)
Works fine, just make sure you take the dust seals offf the inner knuckle.
Old Feb 13, 2002 | 04:12 AM
sensaiGen5's Avatar
Default Re: which axles/int shaft for b20 swap with ys1 (RyanR)
Make sure you doublew check the Tranmission axel seals too!!! if you are doing it youself be carefull when removing the axels. The shop that put mine in f'ed up the right one, bent it all ot hell, so i had tranny fluid all over the bottom of my car foe weeks untill figured out what i was!!!
Good luck!!!
Yuta
22
Apr 29, 2020 02:52 AM
B20Wannabe
14
Jan 9, 2012 03:04 PM
89b20crx
Sep 13, 2009 09:42 AM
slo_ej8
Mar 10, 2008 01:06 PM
jdm_vtec
Aug 30, 2007 11:57 AM
