need help with lcon traction bars. loud clunk when braking and accelerating.
Old Jun 21, 2005 | 06:38 PM
dpine's Avatar
Default need help with lcon traction bars. loud clunk when braking and accelerating.
I've got a problem. I have installed a lcon traction bar for the 88-91 civic. I have run into a problem with a loud clunk sound from the front every time I brake medium or hard, and when I take off. I have the radious rods adjusted(shortest length) down as tight as I can get them. woundering if that could be the problem. how should they be adjusted for daily street driving? please help
Old Jun 21, 2005 | 07:27 PM
bagpipe goatee's Avatar
how they should be adjusted is by your alignment shop. they change caster, and have some other side affects i won't get into.
Old Jun 21, 2005 | 11:10 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: need help with lcon traction bars. loud clunk when braking and accelerating. (dpine)
Check your 3 mounting bolts on each framerail and make sure they are tight, then drive your car to an alignment shop and have it properly adjusted
Old Jun 22, 2005 | 08:44 AM
dpine's Avatar
Default Re: (bagpipe goatee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">how they should be adjusted is by your alignment shop. they change caster, and have some other side affects i won't get into.</TD></TR></TABLE>
would a caster problem cause the clunk sound? what other side effects? also do I adjust the radious rods at the front or the back near the lca. Last question, do the u shape brackets that go on the shock fork go vertical(u shape ends on top and bottom) or horizontol (u shape ends on left and right)? thanks
notwerk
Oct 3, 2006 08:49 PM
DurboDug93
Suspension & Brakes
Mar 16, 2005 04:00 AM
mycivicstoo(s)low
Nov 7, 2003 12:02 PM
tizz
May 22, 2003 12:05 PM
stockgreencivic
Feb 16, 2003 01:21 AM
