obd1 dist plug conversion
i got a obd0-obd1 ecu jumper from blown90hatch, and im trying to wire up my obd1 dist. his instructions are to match color for color, except there are two white wires on the obd0 dist and only one wire on the obd1 dist. which white wire goes to the obd1 dist and which wire does the other white wire connect to?
thanks
thanks
ok, so one white wire on the obd0 goes to the one white wire on the obd1, and the other white wire from the obd0 goes to the obd1 yellow/green. now which white wire?
If you look at the plug with the wires coming toward you, clip facing up.
The fatter white wire will go in the first pin in the upper left.
(sorry i don't have my color chart in front of me right now.)
shoulda bought one of these
http://www.rywire.com/021dizzy.shtml
CRXCRAZYD16Y8
15
Feb 23, 2006 11:32 AM
PA MATT
Oct 29, 2005 10:41 PM
