Torque Specs (D16A8)
Old Jun 21, 2005 | 05:13 PM
importslife's Avatar
Default Torque Specs (D16A8)
I need to find the torque specs for this motor (D16A8) it is close to the (ZC) but a little diffrent. Head bolts, cam bearing bolts, etc. Just got the motor from (Nad Auto) in Norcross for $690.00 motor,trans,hafe shaft,dissy,CAC,intake,and 4-2-1 (zc) manafold the hole swap. Doing the head gasket need specs. PLEASE
Old Jun 22, 2005 | 03:11 AM
Default Re: Torque Specs (importslife)
bump
Old Jun 22, 2005 | 03:23 AM
gutterslide's Avatar
here is the Honda shop manual for this engine.
http://www.honda.co.uk/owner/CRXManual/index.html
and just the head installation section.
http://www.honda.co.uk/owner/C...0.pdf
i got a D16A8 from the same place. does it have the normal ZC valve cover or the striped Rover one?
edit- nevermind, i see it came with a 4-2-1 header, so it's not from a Rover.
Old Jun 22, 2005 | 04:29 PM
Default Re: Torque Specs (gutterslide)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gutterslide &raquo;</TD></TR><TR><TD CLASS="quote">here is the Honda shop manual for this engine.
edit- nevermind, i see it came with a 4-2-1 header, so it's not from a Rover. </TD></TR></TABLE>
thank you!!!!
it has the striped cover DOHC 16 VALVE
Old Jun 22, 2005 | 04:33 PM
whats with the rover part? i dont know
Old Jun 22, 2005 | 06:32 PM
it's a Honda engine from a Rover 216 or 416 GTI. but as far as i know, they all came with 4-1 DX-style exhaust manifolds. maybe they slapped a 4-2-1 on at some point.
it's a good engine, and the only difference (that i know of) between a D16A8 from a Honda and from a Rover is the valve cover design and the color of the spark plug wires. Honda=red, Rover=black w/blue around the end. also, they tend to be newer, since they were used in Rovers until 95-96. i believe you stated in another thread that yours is stamped 93.
more... https://honda-tech.com/zerothread?id=1230071
Old Jun 22, 2005 | 06:34 PM
ServiceAdvisor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importslife &raquo;</TD></TR><TR><TD CLASS="quote">whats with the rover part? i dont know
Honda licensed the D16X motors to the European company Rover. They used it in many of their cars. They have a different valve cover than the Honda D16's so people didn't realize it was a Honda motor. Essentially its a DOHCZC.
Old Jun 22, 2005 | 06:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gutterslide &raquo;</TD></TR><TR><TD CLASS="quote">it's a Honda engine from a Rover 216 or 416 GTI. but as far as i know, they all came with 4-1 DX-style exhaust manifolds. maybe they slapped a 4-2-1 on at some point.
more... https://honda-tech.com/zerothread?id=1230071</TD></TR></TABLE>
yes it is stamped 92 so would be a 93 year modle it came in
Old Jun 22, 2005 | 06:41 PM
oh, another difference... the timing belt cover is white, but i'm sure you already knew that one.
Old Jun 22, 2005 | 06:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gutterslide &raquo;</TD></TR><TR><TD CLASS="quote">oh, another difference... the timing belt cover is white, but i'm sure you already knew that one. </TD></TR></TABLE>
YEP! you are the ******* man you have given me alot of info i can use!
thank you,
Old Jun 22, 2005 | 06:55 PM
oh and he gave me the 4-2-1. i was going with the zc but he went to start it and T/B was broke so he gave me this. But if it is a good motor i will put it in.
Old Jun 22, 2005 | 07:11 PM
it's a good engine. one of the guys at Nad (wtf were they thinking?) said he has one in a CRX. heavy set guy. i don't have any complaints either.
however, i am alittle suspicious of their selling tactics. i wanted a ZC, too. and they told me they had one. when i went to pick it up, all they had was the A8. i asked for a discount since they told me they had a ZC, so they knocked off $100. now, you went for a ZC and all they had was a "broken" one so they pushed another A8. they could have just swapped the TB. i bet they get them for less than a ZC and make a larger profit from selling them for ZC prices. but that's business. and you're still gettting what you're paying for, so i guess it's none of my business how much they profit. just seems alittle dishonest, if they are infact luring people in for a ZC and then offering the A8s.
i need to go see if they can hook me up with a free 4-2-1 header and a PS bracket.
Old Jun 23, 2005 | 03:55 AM
i got all the p/s parts if you want them off of mine and i did look at a zc the first time i went but my boy went to pick it up and thats when he told me it was a broken t/b and gave me the A8 so i did look at a zc ???????????????
jtmoney2002
Sep 16, 2008 05:50 AM
jtmoney2002
Sep 15, 2008 08:29 PM
fernruffryders
Jun 8, 2006 07:48 PM
second edition
Jun 18, 2004 09:14 PM
Ronin Panda
Jun 3, 2003 03:14 PM
