Does the SOHC VTEC ZC uses the same intake manifold as the D16Z6?
Old Jun 21, 2005 | 03:57 PM
d16singlecammer's Avatar
Default Does the SOHC VTEC ZC uses the same intake manifold as the D16Z6?
Before anyone tells me to search I searched quite a bit and did not find anything. I know the D15b intake manifold is different from the D16Z6, but what about the SOCH VTEC ZC does it have the purge solenoid like the D16Z6? Is it the same as the D15b or the same as the D16Z6 intake manifold?. Thanks
Old Jun 21, 2005 | 04:58 PM
d15bcoupe's Avatar
Default Re: Does the SOHC VTEC ZC uses the same intake manifold as the D16Z6? (d15singlecammer)
hmmm i thought the zc was dohc....
Old Jun 21, 2005 | 05:04 PM
chad's Avatar
Moderator
yes sohc intake manifold will work on zc
Old Jun 21, 2005 | 05:05 PM
Default Re: Does the SOHC VTEC ZC uses the same intake manifold as the D16Z6? (d15bcoupe)
no there are sohc zc non v-tec, which are similar to the D16A6, DOHC ZC which are similar to the first model integras, and the one I have is the sohc zc vtec which are very similar to the D16Z6.
Old Jun 21, 2005 | 05:07 PM
Default Re: Does the SOHC VTEC ZC uses the same intake manifold as the D16Z6? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">yes sohc intake manifold will work on zc</TD></TR></TABLE>
I know all sohc intake manifold will work on the zc vtec I have, I wanted to know if the intake manifold that comes in my sohc vtec zc is identical to the z6 with the purge solenoid or is the intake manifold identical to the d15b which doesn't have it.
Thanks
phoQ
22
Nov 11, 2021 07:59 PM
wunest
Feb 24, 2010 11:38 PM
4g4drb17
29
May 22, 2004 10:52 AM
street dreams
Jan 27, 2004 08:47 PM
