my car stalled today!!!!
i drove my car around alittle bit today and stoped to take some pics of it and when i went to leave it started then just stalled out. well i just turned the key off then tried again and it ran perfect. well later i went to walmart and when i came out it would start die start die and start die so i turned the key off and started it back up anbd it started and ran. what do u guys think it might be a 89 crx si with the stock a6, it has 227,000 miles on it. It has new plugs,wires,cap,rotor, and fuel filter. i was kinda leanin towards the fuel pump,anyone else? any help would be much appreciated.
thanks in advance
me
thanks in advance
me
It could be the fuel pump. But I would really look at the distributor. That is a common symptom of distributor on its last life. Have you gotten a check engine light? Sometimes they show crank angle sensor or something similar to that.
i talked to a friend of mine and he said it might be the main relay and he is like a dam honda god,haha. he has a crx drag car. but i dont knw **** yet
When my main relay was going out the car would start normally but if you turn it off after driving it wouldn't start right away. But if I tapped the relay then I would here the pump start.
Try tapping the main relay. It's on the driverside right underneath the dash by the hood pop up switch. I think they are like $60 dealer. not sure cause I work at one and get employee discount.
no cel and it kinda does idle low i have been meanin to idle it up alittle. if i hold my brakes for awhile then let off it idles down and almost dies,ha. thanks for the help so far guys
PayMecracka
11
May 21, 2012 10:49 AM
romierome
Feb 25, 2010 03:17 PM
vtecn8ive
21
Nov 5, 2005 09:35 AM
