help need new clutch and tranny is hard to put in first second and grinds reverse
Old Jun 21, 2005 | 12:09 PM
djsire's Avatar
Default help need new clutch and tranny is hard to put in first second and grinds reverse
the clutch is really weak so im gonna replace it and suggestiuns on whcich clutch to get im gonna go turbo so im gonna need something that holds up to 200 hp
also its really hard to get it into first and second. and when i put it in reverse it grinds a liltle. i searched. and im gonna top off tranny fluid. or try to drain. and put in syncromesh or something. please any reccomendations are apreciated
btw my car is an 89 si with 305,000 miles on it. original everything
Old Jun 22, 2005 | 09:49 AM
djsire's Avatar
Default Re: help need new clutch and tranny is hard to put in first second and grinds reverse (djsire)
anyone got reccomendations please!!!
Old Jun 22, 2005 | 12:19 PM
djsire's Avatar
hellooo!!!
Old Jun 22, 2005 | 12:43 PM
TheBobFather's Avatar
[QUOTE=djsire]the clutch is really weak so im gonna replace it and suggestiuns on whcich clutch to get im gonna go turbo so im gonna need something that holds up to 200 hp
btw my car is an 89 si with 305,000 miles on it. original everything[
Well for starters the car has 300,000+ miles on it. Its 16 years old. Stuff breaks and wears down. With that said, dont even bother putting a turbo on it unless you do a motor swap first or a complete rebuild on the original. You will blow it up. Spend your $ wisely and do it right. Turbocharging a motor with 300,000 miles is NOT a good idea. Common sence imo. Clutchmasters, ATC, ect. for a clutch. Do some homework. Syncros are bad in the tranny so again, rebuild it or swap it.
Cmon Now! Dont do anything untill you learn a thing or two about your car. Education is EVERYTHING
Old Jun 23, 2005 | 07:37 AM
djsire's Avatar
Default Re: help need new clutch and tranny is hard to put in first second and grinds reverse (jnbhonda)
well i dont konw the level or condition of the fluid in the tranny. cant i run that royal prurple stuff? also how does a z6 with harness for 500 sound. the guy said hed give me the tranny for 200 more. but then i would need new axles right?
Old Jun 23, 2005 | 09:52 AM
bagpipe goatee's Avatar
to me, it sounds like your clutch is adjusted way off, dragging all the time. adjust your clutch.
don't get the tranny because the mounts are different and the clutch actuation is different (cable clutch vs. hydraulic clutch).
have him get you the ecu.
don't bother with royal purple or stuff like that. i know people will disagree, let them, but it's just a band-aid fix. in my opinion, it wears out your tranny a lot faster. how most of them work is by putting friction modified stuff in the oil, which coats the synchros and makes them grip, but does it coat the bearings, too?
Old Jun 23, 2005 | 10:40 AM
djsire's Avatar
Default Re: (bagpipe goatee)
i just drove my car and notice when i shift slower it doesnt grind? wtf is going on? also the gears feel a lil looser to get into. also my clutch doesnt fully engage till i get off the clutch pedal and every time i adjsut it to get some free play it ends up back the same way after a day or two. by the way i think the car was sitting for quite a while before i baught it, maybe it just needed to be divrn around to loosen things up?
mark_dc2
Jul 31, 2010 06:00 PM
IBriaIN
Sep 23, 2008 09:01 AM
TerryTate
Sep 30, 2003 02:45 PM
mattL
Apr 14, 2002 04:13 PM
phatintegra
Mar 21, 2002 06:39 PM
