Head swap
I am trying to find out what the differences are between the 88-91 si head and the 92-95 dx head. Are there any, should i just get the si head, or would the dx head work good. I want to switch to multi-point and i am tired of trying to find a decent priced z6 or y8 head. So is the 88-91 head better, what are the differences?
I want to know about a 92-95 dx (non vtec) head. I know it wouldnt be as good as a z6 head but if i could get one cheap then i want to know if i should get it. What kind of performance would i get and what parts do i need.
[Modified by Hayasa15, 5:41 PM 2/12/2002]
well me and typer0207 are both running teh mpfi on our stds with teh 97 dx head i have a y7 head and its almost finished i just need vavle cover bolts so im not using it yet but its probably just as good or better than the a6 head
you don't need to swap the heads. i know for a fact 88-91 DX and 88-91 Si heads are the same (aside from the cam). i don't know about the 92-95 DX head, but the only real difference should be the cam. why not spend the money on a cam instead and gain a solid amount of power (as opposed to 1-2 HP off a non-VTEC head swap). plus, you won't have to remove the whole head to do the cam.
im prety sure the vavle springs are different i know for a fact that teh si cam does work better and the newer heads flow better than the older head hence they make more power and the cam grinds are different also but its not cake changing a cam either
but i would also be switching to multi-point instead of dual-point. and i believe that the multi is better for a turbo. And i plan on doing a custom turbo kit next winter. What parts do i need with this head? Do the distributors, injectors and such swap from the 92-95 or what?
no they dont get a 96 up ex head then u can use ur ecu and dist its the y8 motor and ull get more hp from it higher compression u can use the 88-91 ecu injecters resister and dist
I would like an ex head but i can get a dx head for cheap so i wanted to know if i could use it and if it would be worth getting.
[Modified by Hayasa15, 12:51 PM 2/13/2002]
gsr.tuner
Jun 8, 2008 04:56 PM
4th gen civic racer
Jan 26, 2005 06:39 AM
