Suspension & Brakes Theory, alignment, spring rates....
Koni Yellows
Old Jun 21, 2005 | 11:24 AM
JDR's Avatar
JDR
Default Koni Yellows
i Need help im about to buy a camber kit and i need to kno how much does a the koni yellows drop a car? is it more or less than 1.5 inches? Thanks a bunch.
Old Jun 21, 2005 | 11:29 AM
Corruption's Avatar
The KONI's can go as far as you want, it's all dependant on what kind of spring or coilover you get. Anything under 2" will usually require a camber kit, I'm at 1.75 and I barely made the cut off from needing to get a camber kit for my rear.
Old Jun 21, 2005 | 11:30 AM
00R101's Avatar
Default Re: Koni Yellows (JDR)
1) Why do you think you need to buy a Camber Kit? Our Hondas like some amount of negative camber. It's generally agreed upon here that if you keep the drop to less than 2" then a camber kit is a waste of money - you don't need any camber compensation.
2) Koni Yellows have 3 positions that you can set. The top position is stock height - no drop. Just measure the other positions from the top position to determine your drop (it will actually be a little more than your measurement as the motion ratio of the Honda suspension is less than 1:1)
ramboPandA
Mar 27, 2014 03:15 PM
redef90si
Jul 28, 2010 09:50 PM
George H
Jun 29, 2001 10:32 PM
George H
Jun 14, 2001 04:21 PM
