b16b in ef 4dr
Old Jun 21, 2005 | 10:48 AM
cdorm's Avatar
Default b16b in ef 4dr
hello, i have been reading about the b16b motor and i wanted to know if swaping the b16b into an ef would be some what of a easy swap or not, and worth the money to do?
clay
Old Jun 21, 2005 | 11:05 AM
Grand's Avatar
Default Re: b16b in ef 4dr (cdorm)
putting the motor itself in is not going to be that much of a task however the problem is that the b16b is obd2 where your car is obd0 and the ctr swap comes with a hydralicly operated clutch and you need a cable clutch transmission
so your options to do this swap are to convert your car to obd2 and hydro tranny or get a cable tranny from a first gen b16a or something similar and convert your motor to obd0 using parts from a first gen b16a ie dizzy injectors and probably a few sensors
Old Jun 21, 2005 | 11:33 AM
cdorm's Avatar
ok, well i was looking and the swap comes with a hydro tranny (s4c), so the only thing i would need to do to make this swap work is convert from obd0 to obd2?
Modified by cdorm at 1:16 PM 6/21/2005
19Honda91Sedan
Dec 27, 2011 10:27 AM
stevew84
21
Feb 17, 2009 03:59 PM
StraitRunna
Jan 27, 2009 08:04 PM
LSej1
Feb 20, 2008 05:00 PM
tncivic-dvsb
Mar 4, 2005 07:14 PM
