Who has a Skunk2 IM on a b18 or b20?
Old Jun 21, 2005 | 10:34 AM
BigC-ivic's Avatar
Default Who has a Skunk2 IM on a b18 or b20?
I desperately need to know what is upposed to be attached to the last nipple on the front of the Iintake Manifold farthest away from the Throttle body
I don't have mine hooked up, cuz when I do, the engine stalls
I just put in a P8R head and Crower 403s on my b20... and idle is brutal
Old Jun 21, 2005 | 11:21 AM
Riceintegrars's Avatar
I have 3 pics, hopefully it helps.
U knows those 2 little cylnders near the firewall, theres should be 2hoses coming out of them from the bottom, the one of the left goes in the back of the IM, and the one on the right goes to the front.
Old Jun 21, 2005 | 11:31 AM
BigC-ivic's Avatar
Default Re: (Riceintegrars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riceintegrars &raquo;</TD></TR><TR><TD CLASS="quote">I have 3 pics, hopefully it helps.
I'll try that
so in that last pic, is the blue hose from the front of the IM going under the IM and to the cyliner on the right?
Old Jun 21, 2005 | 11:35 AM
BigC-ivic's Avatar
Default Re: Who has a Skunk2 IM on a b18 or b20? (BigC-ivic)
and where does the hose from the top of the right cylinder thing go?
the top fo the left goes to the FPR right?
Old Jun 21, 2005 | 11:46 AM
The blue hose from the front of the IM goes to the cylinder on the right from the bottom. yes
the top hose from the right cylinder goes all the way to the fuel filter, the big black cylinder on the left side of the car.
and the top left cylinder goes to the FPR correct
Old Jun 21, 2005 | 12:23 PM
BigC-ivic's Avatar
I just tired that.. and the car stalled
BUT... I don't have the b18 TB, I have one from a b20...so the MAP sensor is connected to the TB
I'm thinking of reattachign my b18 map sensor to see how it goes
how may vacuum hookups are there on the b18 MAP sensor?
and where do they go?
(if there is only one then it looks like it goes to the top of the TB)
you are using a b18a TB correct?
Old Jun 22, 2005 | 07:12 AM
BigC-ivic's Avatar
just bumping this to see if anyone else has any ideas or can lend a hand
Old Jun 27, 2005 | 12:24 PM
b17gsr's Avatar
I've seen some JDM B16A that totally bypass those two sensors on the firewall. Might due to the ECU that was being used.
Old Jun 28, 2005 | 06:04 AM
BigC-ivic's Avatar
I just pulled my b20TB off the Skunk2 IM so I could put the b18 TB back on and I noticed that while both TB's have two holes where they connect to the IM, the Skunk2 IM only has one hole
I know one of them leads to the IACV... the one that my Skunk2 IM still has
but the one it is missing leads to the FITV
I believe the FITV on the b18 is connected to the factory IM, whereas on the b20 TB it is on the TB
could the IM be the source of my shitty idle?
Old Jun 28, 2005 | 06:19 AM
b17gsr's Avatar
What do you mean by hole? Sensor mounting location?
The ITR doesn't have a FITV, and it idles fine.
Old Jun 28, 2005 | 07:40 AM
BigC-ivic's Avatar
Default Re: (b17gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b17gsr &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean by hole? Sensor mounting location?
The ITR doesn't have a FITV, and it idles fine.</TD></TR></TABLE>
there are two passageways, built inside the stock IM, and the stock TB has two holes on the inside where these are supposed to connect to
the IACV has one... and the passageway presumably leads to the IACV... a for the other... there is no hole in the IM that connects to the TB
Old Jun 28, 2005 | 09:06 AM
BigC-ivic's Avatar
Default Re: (BigC-ivic)
GOOD NEW/bad news
(Knock on wood) the car appears to idle perfectly.. yippee!
Bad news.... I now have a check engine light... so I'll have to have my codes read.. ah well, I'm sure its nothign major
Old Jun 28, 2005 | 11:22 AM
BigC-ivic's Avatar
Guess what, I forgot to attach the sensor on the back of the TB
so I did that and THE IDLE SUCKS AGAIN
but the check engine light went off
I didn't have time to fiddle with the idle screw
and the throttle is really slack right now.. I'll have to tighten that up
Old Jun 29, 2005 | 08:22 AM
BigC-ivic's Avatar
so I got it to idle properly with a little fiddling of the throttle cable... it idles around 1000, anything lower and the revs will rise and fall
The problem is that now it seems I am losing fuel pressure
If the car has been sitting for a long time (like over-night) I have to manually use the FPR to up the fuel, start the car, then I have t ogo back and lower the fuel pressure
also, the FPR measures 50 psi when the vacuum hose isn't attached, but as soon as I attach it, it drops to 40. (Is this normal)?
skeme1
Mar 16, 2007 12:43 AM
skUnK2jdm
Feb 6, 2007 03:28 AM
CRXCrazy123
May 4, 2005 08:21 AM
SyDuck
Apr 16, 2005 11:02 PM
