Greddy turbo timer not working correctly?
Old Jun 21, 2005 | 10:30 AM
trooper0641's Avatar
Default Greddy turbo timer not working correctly?
This is in my 88 crx, I wired...
red - white
blue - yellow
green - yellow/black
black - ground
Well it turns on, I guess...it shows -L- at the very begining...i set it to 1.00 min....but when I shut off the car, the turbo timer doesnt stay on but shuts off with it.
Old Jun 21, 2005 | 12:41 PM
Default Re: Greddy turbo timer not working correctly? (trooper0641)
help a brother out.
Old Jun 21, 2005 | 01:15 PM
hyelp me bitches n hoes!
Old Jun 21, 2005 | 01:36 PM
EK_GSR's Avatar
!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">hyelp me bitches n hoes!</TD></TR></TABLE>
well if i was thinking about helping you, that comment def. made up my mind...
it should turn off i have some schematics at home i will look at them.. and see if i can figure out where you messed up on the install....
Old Jun 21, 2005 | 06:21 PM
Default Re: Greddy turbo timer not working correctly? (EK_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_GSR &raquo;</TD></TR><TR><TD CLASS="quote">!
it should turn off i have some schematics at home i will look at them.. and see if i can figure out where you messed up on the install.... </TD></TR></TABLE>
haha i was just messing around, its called sarcasm
Old Jun 21, 2005 | 08:00 PM
32rd32qdzxdsdds
Old Jun 21, 2005 | 08:57 PM
dfgdhfetjwrtjwrtg
Old Jun 21, 2005 | 10:46 PM
kraig8's Avatar
make sure your not using a switched on power becuase when you turn off your car so will the turbo timer. find a constent power.
Old Jun 21, 2005 | 10:54 PM
Default Re: (kraig8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kraig8 &raquo;</TD></TR><TR><TD CLASS="quote">make sure your not using a switched on power becuase when you turn off your car so will the turbo timer. find a constent power. </TD></TR></TABLE>
constant power, like from my battery? so I should run my red to battery?
Old Jun 22, 2005 | 06:54 AM
EK_GSR's Avatar
Default Re: (trooper0641)
yea if you havent found a source of constant power than it will not work.....
Old Jun 22, 2005 | 08:36 AM
Default Re: (EK_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_GSR &raquo;</TD></TR><TR><TD CLASS="quote">yea if you havent found a source of constant power than it will not work..... </TD></TR></TABLE>
shouldnt the power come from my red - to the white ignition wire?
Old Jun 22, 2005 | 10:44 AM
243r2r3wfsdsdf34f3ff3f3fffds
Old Jun 22, 2005 | 11:12 AM
q2dq3q3wqewqfwe
Old Jun 25, 2005 | 11:05 PM
21e3rr3
Old Jun 27, 2005 | 12:18 AM
ADcsdbsv
Old Jun 27, 2005 | 11:36 AM
23423r
Old Jun 27, 2005 | 03:39 PM
w23r32q32
Old Jun 27, 2005 | 10:56 PM
help me baby
Old Jun 28, 2005 | 01:42 AM
23r32wesd
Old Jun 28, 2005 | 11:45 AM
23r32r3ffwewe
Old Jun 28, 2005 | 08:44 PM
im dying
Old Jun 28, 2005 | 10:09 PM
lkailburn's Avatar
ugh i hate my greddy unit. i've had it wired just like you have it and it worked sometimes didn't work other times. sometimes would work then kick itself back on after random amounts of time. i also switched the blue wire to the white/black stripe. thought it was working but then started acting the same. i think the greddy unit is junk. i've heard others with the same story too. i wish i could help but all i can say is verify all your wiring and make sure you test the two ign wires so you know for sure you have it wired up like it says to in the booklet
Old Jun 29, 2005 | 04:44 AM
JDMTurboCivic11's Avatar
Default Re: (lkailburn)
im having the same problems....the unit will shut off when i shut the car off, sometims it will work, either will count down from my set time or set its own time? Agreed tht the unit is junk
Old Jun 29, 2005 | 06:24 AM
lkailburn's Avatar
to greddy
Old Jun 29, 2005 | 09:35 AM
tthame1's Avatar
you guys should just buy the tt harnesses that lightning motorsports sells, it only takes 5 minutes to install plug and play.
http://shopping.lightningmotor...t=265
