Downshift w/ turbo?
Old Feb 12, 2002 | 09:13 AM
td04civic's Avatar
Default Downshift w/ turbo?
I was reading somewhere and it said that you can't downshift when you're running a turbo. Is this true? Could you damage your motor or turbo by downshifting?
Old Feb 12, 2002 | 09:16 AM
GSRacer's Avatar
New User
Default Re: Downshift w/ turbo? (td04civic)
i downshifted all the time when i had my turbo gsr. good question though. i'm also curious...
Old Feb 12, 2002 | 09:44 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Downshift w/ turbo? (GSRacer)
I don't see why it would. There has to be load on the motor to build boost. If you simply downshift, your rpms climb, but you're not boosting. It should be fine.
That would suck if you weren't supposed to downshift with a turbo.
Old Feb 12, 2002 | 09:48 AM
BoM's Avatar
BoM
Default Re: Downshift w/ turbo? (shamoo)
just downshift smart.
downshifting into 3rd while going 80 isn't smart. u'll be at 7k rpms.
downshifting into 4th would be better u'll be directly into boost
depending on your turbo
Old Feb 12, 2002 | 09:58 AM
SiR Kid's Avatar
New User
What's so bad about downshifting to 7k rpm?
Rev it to 9, it'll take it if it's built right!
Old Feb 12, 2002 | 10:26 AM
dustin's Avatar
Default Re: Downshift w/ turbo? (SiR Kid)
Of course you cannot downshift with a turbo!
In fact, ever since I put the turbo on I have just left the car in 5th gear... Sometimes starting from a stop sucks in 5th gear, but you get used to it... the honking from all the cars behind you gets annoying sometimes, though.
Basically, the turbo system disables all gears fourth and below in the transmission.
Now, on a more serious note..
Of /course/ you can downshift. You will accelerate the fastest by going to the lowest gear possible to keep your revs below the rev limiter! It's called gearing.
And no, at 80mph (assuming a GSR) you would definately want to put it in 3rd gear, not fourth. If I hear the phrase "Cause it keeps you in boost longer" once more I am going to shoot myself in the head.
Dustin
Old Feb 12, 2002 | 10:48 AM
ZygSpeed's Avatar
Default Re: Downshift w/ turbo? (dustin)
Dustin
very funny!
... that stuff about disabling fourth and below...
So it's a two speed, forward and reverse!
Old Feb 12, 2002 | 11:01 AM
SiR Kid's Avatar
New User
Default Re: Downshift w/ turbo? (zygspeed)
Turbo doesn't work in reverse... all the power is blown out the blow off valve in reverse... You have to push the car if you need to back up...
Old Feb 12, 2002 | 11:06 AM
dustin's Avatar
Oh yeah, cause I forgot the motor spins the other way in reverse... Stupid me
Old Feb 12, 2002 | 11:09 AM
D-Man's Avatar
with or without turbo it dont make a diff if you downshift,true itll add more ware and tear to motor and drivetrain but its the same with or without the turbo,also,there are a ton of road race cars that use Turbos,that downshift hundreds of times in a race.
Old Feb 12, 2002 | 11:13 AM
ZygSpeed's Avatar
Default Re: Downshift w/ turbo? (D-Man)
... also,there are a ton of road race cars that use Turbos,that downshift hundreds of times in a race.
I believe they use mega-volume adjustable anti-chirp valves.
Or was it that they do chirp?
Old Feb 12, 2002 | 12:00 PM
01geeser's Avatar
New User
just rev match and youll be fine
Old Feb 12, 2002 | 12:05 PM
VTC_CiViC's Avatar
I heard Elvis is alive and drives an ITR... it must be true, after all.. I heard it
[Modified by VTC_CiViC, 4:05 PM 2/12/2002]
Old Feb 12, 2002 | 12:18 PM
D-Man's Avatar
Default Re: Downshift w/ turbo? (VTC_CiViC)
Naa,Elvis is too fat to fit in an ITR and he's a cadillac man.
Old Feb 12, 2002 | 12:24 PM
VTC_CiViC's Avatar
LOL, must have been a Cadillac with "Type R" stickers then
Old Feb 12, 2002 | 03:19 PM
FBP Si 2000's Avatar
I downshift from time to time...nothing wrong with it...
Old Feb 12, 2002 | 03:23 PM
cyan1de's Avatar
Dustin
wtf are you talking about?!?!?! u should put it in 4th cause it keeps you in boost longer!!!
Old Feb 12, 2002 | 05:01 PM
bigTom's Avatar
Default Re: Downshift w/ turbo? (cyan1de)
i say put in in third so ur in boost longer... better yet... get an ls tranny... then ull really be in boost longer!
Old Feb 12, 2002 | 05:03 PM
dustin's Avatar
Default Re: Downshift w/ turbo? (Tom)
WTF are you talking about you idiot Tom.
I am in boost ALL THE TIME cause my car is ALWAYS in 5th gear.. you CANNOT DOWNSHIFT with a turbo.
Old Feb 12, 2002 | 05:05 PM
bigTom's Avatar
now that i think about it u may be correct... but i bet ill go faster than u with my ls transmission... everyone always tells me u go faster with them!
Old Feb 12, 2002 | 05:06 PM
dustin's Avatar
LS transmission + JRSC, and you'll be running nines.
Tom, when you had the LS transmission, I told you ya had a whole in your fuel curve. You need to lengthen the injected pulse!!!!!
You mess with the bull, you get the horns!!!!!
Old Feb 12, 2002 | 05:09 PM
bigTom's Avatar
with that extra 500 shot ill do 8's!
Old Feb 12, 2002 | 05:10 PM
dustin's Avatar
You got a heavy foot, you'll blow yourself to pieces.
Old Feb 12, 2002 | 05:18 PM
TurboSedan's Avatar
New User
AMATEUR'S DON'T USE NITROUS OXIDE!!!!!!!!
Old Feb 12, 2002 | 05:55 PM
bigTom's Avatar
Default Re: Downshift w/ turbo? (97CivicFerio)
hey buddy! stay outta this... u still owe me a 10-second car!
