87 CRX Not Starting HELP!!!
Old Jun 21, 2005 | 07:51 AM
Simon Tibbett's Avatar
Default 87 CRX Not Starting HELP!!!
I have a 87 CRX HF, yes old school, and I was driving my gf home and it shut off. Not stalling sitting still I mean 60mph boom stops running. So I pull over, check for any obvious things, none. Try starting it turns over and over and just wont do anything. Luckily my friend was behind us he towed my car home. I checked for spark and the car turns over and sparks right when it turns over and thats it, so like one or two sparks is all I see. It is getting gas. I changed the coil and put a new rotor in. Any ideas? I am lost, the car is for sale and this is not a good way to sell a car.
Old Jun 21, 2005 | 07:53 AM
86si's Avatar
Default Re: 87 CRX Not Starting HELP!!! (Simon Tibbett)
t- belt sounds like it broke or some teeth on the belt ripped off
Old Jun 21, 2005 | 10:21 AM
Rex_Ryder's Avatar
Check your distributor rotor. Happened to me when I was on the freeway too doing 70mph. I got home and check the rotor and the screw came loose. All it took was a slight misalignment of the rotor to cause it not to start.
Old Jun 21, 2005 | 11:08 AM
LShatchie's Avatar
Default Re: 87 CRX Not Starting HELP!!! (Nu_At_It_CRX)
definatly sounds like some sort of an electrical problem
Old Jun 21, 2005 | 11:54 AM
well the rotor is on, I will make sure it is tight. i started to take the t-belt cover off but got side tracked looking around the dizzy, could it be an ignition switch?
Old Jun 21, 2005 | 01:34 PM
ok the timing belt was fine
HatchGirl89
Nov 15, 2012 10:00 AM
portugino_69
13
Jan 26, 2007 06:00 PM
trompeta performance
Jan 9, 2007 07:04 PM
balistik
Mar 25, 2005 08:12 AM
RedRacerCivic
Jan 10, 2002 06:14 PM
